Retrieving primary line DN on a Device
Mamdouh Elgamal
i'm working on a java tool that accomplishes the following:
loop through a string array of CUCM end user userIds ---> check if enduser is associated with a device ---> get device name and run following SQL Query
String sqlQuery = "select numplan.dnorpattern, devicenumplanmap.e164mask from device, numplan, devicenumplanmap "
                + "where device.pkid = devicenumplanmap.fkdevice and "
                + "numplan.pkid = devicenumplanmap.fknumplan and device.name="+"'"+deviceName+"'";
Make a ExecuteSQLQueryReq
                ExecuteSQLQueryReq sqlReq = new ExecuteSQLQueryReq();
                sqlReq.setSql(sqlQuery);
                ExecuteSQLQueryRes sqlRes = axlPortReq().executeSQLQuery(sqlReq);
                sqlReturn = sqlRes.getReturn().getRow();
                Element returnValue = (Element)sqlReturn.get(1);
                dNumber = returnValue.getElementsByTagName("dnorpattern").item(0).getFirstChild().getTextContent();
                e164Mask = returnValue.getElementsByTagName("dnorpattern").item(0).getNextSibling().getTextContent();
                if(!e164Mask.toLowerCase().equals("null")) line = phoneDescription+","+dNumber+","+e164Mask;
                else if(e164Mask.toLowerCase().equals("null")) line = phoneDescription+","+dNumber+",No Mask";
print string line:
System.out.println(line);
The problem i'm runing into is the following:
if the device has a secondary(Line 2) shared line(shared with other devices) on it, the sql query request returns the shared line and not the primary line DN
I'm able to retrive the primary line dn only when i do the following:
change
to
dNumber = returnValue.getElementsByTagName("dnorpattern").item(1).getFirstChild().getTextContent();
my question is, why is it returning the shared secondary line DN vs the primary line DN ?
I also tried to make a GetPhoneReq vs the SQL query to obtain the primary line DN, but still same issue.
CUCM version is 10.5.1.10000-7
i can share more code if needed. Thanks
Mamdouh Elgamal
figured it out
changed the query to the following: String sqlQuery = "select numplan.dnorpattern, devicenumplanmap.e164mask from device, numplan, devicenumplanmap "+ "where device.pkid = devicenumplanmap.fkdevice and " + "numplan.pkid = devicenumplanmap.fknumplan and numplanindex = 1"+ "and device.name="+"'"+deviceName+"'";
