RTSP Stream terminnating Prematurely
banderson614
We are requesting RTSP streams of calls that MediaSense is currently recording, but after 120 seconds the streams terminate. Since in the response to the initial play request we get “timeout=120” this appears to be an issue with the session timing out. We have tried sending both Play and Options messages for the same session  prior to the 120 seconds in order to prevent the session from timing out, but this has not worked. We are seeing this in our lab and at a customer's site so i do not believe that it is environmental.
Here is a pcap tcp trace of our request to the MediaSense and it's responses to us
Highlighted in yellow = Coming from Uptivity   Highlighted in green = Coming from Mediasense
OPTIONS rtsp://10.105.30.196/eca1454785bdad1 RTSP/1.0
CSeq: 1
User-Agent: CC_RTSP_Client
Authorization: Basic Y3RpdXNlcjpjdGl1c2Vy
RTSP/1.0 200 OK
Server: Cisco MediaSense Media Server
CSeq: 1
Public: DESCRIBE, PLAY, SETUP, SET_PARAMETER, GET_PARAMETER, TEARDOWN, PAUSE, RECORD, OPTIONS
DESCRIBE rtsp://10.105.30.196/eca1454785bdad1 RTSP/1.0
CSeq: 2
Accept: application/sdp
Accept-Language: en-US
RTSP/1.0 302 Moved Temporarily
CSeq: 2
Location: rtsp://10.105.30.196:9554/eca1454785bdad1?token=eca1454785bdad1^LA^0^0^0^1397064633^d0ab401d956c9fd0ae23ec7e8c1915f49cb6e9e8
DESCRIBE rtsp://10.105.30.196:9554/eca1454785bdad1?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822 RTSP/1.0
CSeq: 3
        RTSP/1.0 200 OK
CSeq: 3
Content-Base: rtsp://10.105.30.196:9554/eca1454785bdad1/
Content-Type: application/sdp
Content-Length: 743
v=0
o=- 15487880279310217208 15487880279310217808 IN IP4 10.105.30.196
s=Cisco Live Media Streaming Session
e=NONE
c=IN IP4 10.105.30.196
u=rtsp://10.105.30.196:9554/eca1454785bdad1
t=0 0
a=control:rtsp://10.105.30.196:9554/eca1454785bdad1?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822
m=audio 0 RTP/AVP 0 13
a=range:npt=now-
b=AS:8000
a=control:rtsp://10.105.30.196:9554/Pool_Device_122/Audio_Pool_122?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822
a=range:npt=now-
b=AS:8000
a=control:rtsp://10.105.30.196:9554/Pool_Device_123/Audio_Pool_123?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822
SETUP rtsp://10.105.30.196:9554/Pool_Device_122/Audio_Pool_122?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822 RTSP/1.0
CSeq: 4
Transport: RTP/AVP;unicast;client_port=6970-6971
x-retransmit: our-retransmit
x-dynamic-rate: 1
x-transport-options: late-tolerance=2.900000
RTSP/1.0 200 OK
CSeq: 4
Session: 747595639;timeout=120
Transport: RTP/AVP;unicast;client_port=6970-6971;server_port=24576-24577;mode="PLAY";ssrc=516173345
SETUP rtsp://10.105.30.196:9554/Pool_Device_123/Audio_Pool_123?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822 RTSP/1.0
CSeq: 5
Transport: RTP/AVP;unicast;client_port=6972-6973
Session: 747595639
x-dynamic-rate: 1
RTSP/1.0 200 OK
CSeq: 5
Transport: RTP/AVP;unicast;client_port=6972-6973;server_port=24578-24579;mode="PLAY";ssrc=516173346
PLAY rtsp://10.105.30.196:9554/eca1454785bdad1?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822 RTSP/1.0
CSeq: 6
Session: 747595639
Range: npt=0.000000-
x-prebuffer: maxtime=2.000000
RTSP/1.0 200 OK
CSeq: 6
Session: 747595639
RTP-Info: url=rtsp://10.105.30.196:9554/Pool_Device_122/Audio_Pool_122;seqno=61268,url=rtsp://10.105.30.196:9554/Pool_Device_123/Audio_Pool_123;seqno=37325
Range: npt=0.00-
OPTIONS rtsp://10.105.30.196:9554/eca1454785bdad1?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822 RTSP/1.0
CSeq: 7
Session: 747595639
RTSP/1.0 200 OK
CSeq: 7
Session: 747595639
Public: DESCRIBE, SETUP, PLAY, PAUSE, TEARDOWN, PAUSE, GET_PARAMETER, SET_PARAMETER, ANNOUNCE
TEARDOWN rtsp://10.105.30.196:9554/eca1454785bdad1?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822 RTSP/1.0
CSeq: 10
Session: 747595639
RTSP/1.0 454 Session Not Found (Session <747595639> not found)
CSeq: 10
Session: 747595639
I have also attached the MediaSense API service and Call control services logs for a different example:
MediaSense IP: 10.105.30.196
Our service IP: 10.100.5.124
Test call with trace log:
RTSP URI: rtsp://10.105.30.196/eca1454785bdad1
SessionId: 747595639
The test call start at: 2014-04-09 13:25:17.330 Debug 0 Stream Detected - Remote Recording Start with RTSP URI:rtsp://10.105.30.196/eca1454785bdad1
RTSP setup message send: 2014-04-09 13:25:30.285 Debug   0 RTSP Request message:["OPTIONS rtsp://10.105.30.196/eca1454785bdad1 RTSP/1.0","CSeq: 1","User-Agent: CC_RTSP_Client","Authorization: Basic Y3RpdXNlcjpjdGl1c2Vy","",""]
RTSP Play message send: 2014-04-09 13:25:32.987 Debug   0 RTSP >> Request message:"PLAY rtsp://10.105.30.196:9554/eca1454785bdad1?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822 RTSP/1.0\r\nCSeq: 6\r\nUser-Agent: CC_RTSP_Client\r\nAuthorization: Basic Y3RpdXNlcjpjdGl1c2Vy\r\nSession: 747595639\r\nRange: npt=0.000000-\r\nx-prebuffer: maxtime=2.000000\r\n\r\n"
Repeating option messages:
2014-04-09 13:27:27.974 Debug 0 RTSP >> Request message:"OPTIONS rtsp://10.105.30.196:9554/eca1454785bdad1?token=eca1454785bdad1^LA^0^0^0^1397064634^e5833cdd052f0b8f1f9aa63d530c08922d641822 RTSP/1.0\r\nCSeq: 7\r\nUser-Agent: CC_RTSP_Client\r\nAuthorization: Basic Y3RpdXNlcjpjdGl1c2Vy\r\nSession: 747595639\r\n\r\n"
Last UDP message send by MediaSense: 2014-04-09 13:27:33.748102
Stream duration: 13:25:33.052665 ~ 13:27:33.748102 (see AudioStreamStart.png and AudioStreamStop.png))
mbenenso
MS use ICMP ping to check, if client ip is available, if MS does not receives responses to ping, it will stop sending playback RTP
I do not see ICMP pings in the tcpdump, seems ping from MS box to the client box does not come through.
could you, please:
1. verify that you could ping client ip from the MS box using CLI command
-- utils network ping <client_ip> count 10
2. If tcpdump was collected on Client box, collect it on MS box, using CLI command
--- utils network capture file tcpdump1 count 100000 size ALL
and then download pcap to your sftp serevr, using CLI command
--- file get activelog platform/cli/tcpdump1.cap
