When I deployed an application (a simple CentOS image) I'm getting an error "Node is not accesible" and the status message is "Instance bootstrapping is timed out, possibly due to incorrect or missing agent bundle for node 420c1ff7-4b80-dffa-34db-541c9d976e40". I can able to access the deployed VM in Vcenter when the deployment status is "In-Progress", after that I'm getting the above mentioned error.
Can anyone provide solution for it.
Thanks in advance.
Nayeemuddin Sheriff
