WLC98k Configure AP Tags through Netconf
0_Kiss
Hi all
I'm trying to add Tags through netconf to an Access Point on a WLC98k (17.3.1).
Here is the code:
from ncclient import manager
insert_ap_cfg_data = '''
<ap-cfg-data xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-wireless-ap-cfg">
    <ap-tags>
        <ap-tag>
            <ap-mac>a4:53:0e:39:d3:f8</ap-mac>
            <policy-tag>policy-tag</policy-tag>
            <site-tag>site-tag</site-tag>
            <rf-tag>rf-tag_typical_density</rf-tag>
        </ap-tag>
    </ap-tags>
</ap-cfg-data>
wlc = {"host": "10.90.255.180", "port": "xxx", "username": "xxx", "password": "xxx"}
with manager.connect(host=wlc['host'], port=wlc['port'], username=wlc['username'], password=wlc['password'], hostkey_verify=False, device_params={'name':'iosxe'}) as wlc_con:
    connected = wlc_con.connected
    if connected:
            print('Connection to ' + wlc['host'] + ' established!\n')
            reply = wlc_con.edit_config(target='running', config=insert_ap_cfg_data)
            print(reply)
But all I'm getting is this error:
[root@ansible temp]# python3 wlc98k_config_ap.py
Connection to 10.90.255.180 established!
Traceback (most recent call last):
  File "wlc98k_config_ap.py", line 46, in <module>
  File "/usr/local/lib/python3.6/site-packages/ncclient/manager.py", line 231, in execute
    huge_tree=self._huge_tree).request(*args, **kwds)
  File "/usr/local/lib/python3.6/site-packages/ncclient/operations/edit.py", line 65, in request
    node.append(validated_element(config, ("config", qualify("config"))))
  File "/usr/local/lib/python3.6/site-packages/ncclient/xml_.py", line 150, in validated_element
    raise XMLError("Element [%s] does not meet requirement" % ele.tag)
ncclient.xml_.XMLError: Element [{http://cisco.com/ns/yang/Cisco-IOS-XE-wireless-ap-cfg}ap-cfg-data] does not meet requirement
What am I missing here?
Best regards,
Oli
12 Replies 12
0_Kiss
I changed the netconf payload to this:
<config>
    <ap-tags>
      <ap-tag>
      </ap-tag>
    </ap-tags>
  </ap-cfg-data>
</config>
But now I am getting this message:
  File "wlc98k_config_ap.py", line 15, in <module>
    reply = wlc_con.edit_config(target='running', config=netconf_payload)
  File "/usr/local/lib/python3.6/site-packages/ncclient/operations/edit.py", line 69, in request
    return self._request(node)
  File "/usr/local/lib/python3.6/site-packages/ncclient/operations/rpc.py", line 360, in _request
    raise self._reply.error
ncclient.operations.rpc.RPCError: {'type': 'protocol', 'tag': 'unknown-element', 'app_tag': None, 'severity': 'error', 'info': '<?xml version="1.0" encoding="UTF-8"?><error-info xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0"><bad-element>config</bad-element>\n</error-info>\n', 'path': '\n    /rpc/edit-config\n  ', 'message': None}
Any ideas?
It is possible that YANG model Cisco-IOS-XE-wireless-ap-cfg.yang is not included in your router's configuration. Please check your router's YANG capabilities:
ssh -p <netconf-port> <username>@10.90.255.180 -s netconf
Yan Gorelik
YDK Solutions
Hi Yan
The module is included. I was able to read the Access Point configuration through "get-config" without any issues. I basically copied the "get-config" output to create the configuration snippet.
It might be an issue with the Software version, someone else is facing something similar:
https://community.cisco.com/t5/yang-development-kit-ydk/netconf-error-in-ios-xe-17-3-1a-but-works-fine-on-ios-xe-16-12-4/m-p/4146535#M1670
I'm going to try an earlier release and report back if it fixed it.
Oli
I can now confirm that the script runs on a WLC with version 16.12.4a but not on one with version 17.3.1. Yang model is identical.
WTH Cisco?!
I am getting this on 17.3.1
CCNP - Wireless
CWNE #136
Same as me :-(
Here is an interesting observation I made: Yesterday I installed the advanced netconf explorer (https://github.com/cisco-ie/anx) and used its Netconf console to configure the WLC.
I tried this snippet on a WLC98k 17.3.1:
<edit-config xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <target>
    <running/>
  </target>
  <config>
      <ap-tags>
        <ap-tag>
          <ap-mac>10:10:10:10:10:10</ap-mac>
          <policy-tag>policy_test_tag</policy-tag>
          <site-tag>site_test_tag</site-tag>
          <rf-tag>rf_test_tag</rf-tag>
        </ap-tag>
      </ap-tags>
    </ap-cfg-data>
  </config>
</edit-config>
It worked with the advanced netconf explorer:
Then I removed the "edit-config" and "target" part of the snippet so it looked like this:
<config>
    <ap-tags>
      <ap-tag>
      </ap-tag>
    </ap-tags>
  </ap-cfg-data>
</config>
And then I called it with the python ncclient:
reply_raw = wlc_con.edit_config(target='running', config=netconf_payload)
This did not work on 17.3.1 but worked on 16.12.4a. I think there might be a communication issue between the ncclient and the WLC.
Oli
mine fails through netconf explorer
<config>
    <wlan-cfg-data xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-wireless-wlan-cfg">
      <wlan-cfg-entries>
        <wlan-cfg-entry xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-wireless-wlan-cfg">
        <profile-name xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-wireless-wlan-cfg">WT-Python</profile-name>
        <wlan-id xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-wireless-wlan-cfg">204</wlan-id>
        <auth-key-mgmt-psk xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-wireless-wlan-cfg">true</auth-key-mgmt-psk>
        <auth-key-mgmt-dot1x xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-wireless-wlan-cfg">false</auth-key-mgmt-dot1x>
        <psk xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-wireless-wlan-cfg">12345678</psk>
        <radio-policy xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-wireless-wlan-cfg">apf-vap-radio-80211a-only</radio-policy>
        <apf-vap-id-data xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-wireless-wlan-cfg">
            <broadcast-ssid xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-wireless-wlan-cfg">true</broadcast-ssid>
            <ssid xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-wireless-wlan-cfg">WT Python</ssid>
            <wlan-status xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-wireless-wlan-cfg">true</wlan-status>
        </apf-vap-id-data>
        </wlan-cfg-entry>
      </wlan-cfg-entries>
    </wlan-cfg-data>
</config>
Gives me
<rpc-error xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <error-type>protocol</error-type>
  <error-tag>operation-not-supported</error-tag>
  <error-severity>error</error-severity>
  <error-info>
  </error-info>
</rpc-error>
This worked on 16.12.4a as well
CCNP - Wireless
CWNE #136
Thanks everyone. Can confirm, had the same error on 17.3.1 but rolled back to 16.12.4a and its working as expected.
aihassan1
I can confirm i am having the same issue as mentioned above. I can run a python script to my WLC on 16.12.x code. However, I'm unable to perform the same function with my WLC on 17.x.x code. it still looks like an issue between ncclient and the WLC on 17.x.x.
I this just a perm broken ? did anyone fix this ?
CCIE-Collaboration #24527
JPavonM
Thanks for very helpful link!
I changed the following RPC:
  <ap-tags>
    <ap-tag>
    </ap-tag>
  </ap-tags>
</ap-cfg-data>
To this:
<config xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
        <ap-tags>
            <ap-tag>
                <policy-tag>policy_tag</policy-tag>
                <site-tag>site_tag</site-tag>
            </ap-tag>
        </ap-tags>
    </ap-cfg-data>
</config>
This way it works now! I tested it on 17.3.4
