Cisco Prime and WLC HA-SSO
aseghezzi
Hi All.
i implemented the HA_SSO on two wlc, WLC1 Active and WLC2 Hot Stanby and the system works fine.
My question reguarding the monitoring. Is Possible monitoring  to the WLC Secondary?
if by chance the wlc standby should be broken as I can realize this fault?
Leo Laohoo
Currently, the answer is NO.  Wait a few more months.  If I remembered correctly, this feature has been asked several times and might actually be incorporated with CPI 3.0 which is rumoured to be released on May/June 2015.
