Cisco Smart Software Manger LDAP TLS Handshake failed
alois.heilmaier
- configured ldap on the smart software manager on prem  (cssm).
- but on submitting the configuration I get a connection error.
- wireshark trace shows an Internal Server Error (80) (sent from the client)
- it does not matter if I enable or disable cert validation on cssm.
- There is no log for ldap on the system. Seems that ldap is hidden in docker container "backend"
- parsing /var/log/messages, does not show any useful information.
Any hints on how to debug ldap and tls connectoin errors on the system ?
Best regards
Alois
marce1000
 - Usually due to a cipher-mismatch issue, which client+version are you using ?
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
unfortunately there is a match in the cipher suite. (uses 0x0033 TLS_DHE_RSA_WITH_AES_128_CBC_SHA)
I thought about the many extions parameters the client provides, but if the server can't fulfull them, i think there will be an error on the server side.
Due to the error I upgraded vom 08-202004 to the newest 08-202006 Version of cisco smart software manager.
