I'm trying to set up power control rules for my Ubuntu 14.04 in Energywise Management. I manually add the PC and set SSH method. Everything works well except Check Status method. When the PC is on, status is correct, but when the PC is off, the Check Status returns error: SSH port (22) is not reachable.
Thank you for any help or suggestions,
Dominik
