how to convert Cisco Prime Infrastructure for Vmware workstation
vuonghongvu
Dear all
I had installed Cisco Prime Infrastructure on VMWare ESX 4 server. I want convert it to vmware workstation 8.
vuonghongvu
I had used VMware vCenter Converter Standalone Client 5. But when I run on vmware workstation 8, it not run. When i used " ncs status" command line, it display
How to resolve it ?
Thank you so much.
Maybe a little bit off topic, I have ESXi5.0 running as VM in VMware Workstation and then deploy Prime Infrastructure 1.2 in that ESXi. I got the same result as you do. After using the "ncs start" and use "ncs status" to check the system status, only NCS server is not running. No idea to solve it. Just my 2 cents.
To both the OP and mna:
You're trying to run unsupported untested and "undesigned-for" installations. Cisco Prime Infrastructure (and LMS) is quite particular about you meeting the hardware and software requirements specified in the Installation Guide.
