06-18-2010 11:23 PM
We installed LMS 3.2 on windows server 2003 enterprise edition. RME version is 4.3.1. We have created daily syslog purge job from RME> Admin> Syslog> Set Purge Policy. This job failes with the following error.
"Drop table failed:SQL Anywhere Error -210: User 'DBA' has the row in 'SYSLOG_20100516' locked 8405 42W18
[ Sat Jun 19 01:00:07 GMT+05:30 2010 ],ERROR,[main],Failed to purge syslogs"
After server restart job will again execute normally for few days.
Please check attached log file of specified job.
06-19-2010 06:44 PM
Instead of restarting the server, try restarting the SyslogAnalyzer daemon alone. Does the purge job run successfully after that?
pdterm SyslogAnalyzer
pdexec SyslogCollector
07-21-2010 10:47 PM
I restarted SyslogAnalyzer daemon alone, still i am getting same error.
07-22-2010 09:53 PM
How many purge jobs exist? You can find a list of them under Common Services > Server > Admin > Job Browser.
07-22-2010 11:14 PM
We have configured only one SyslogDefaultPurge job.
07-24-2010 09:31 AM
The only reports of this problem in the past has been with two jobs being created during an upgrade. This would not have been something you would have done yourself. I suggest you open a TAC service request so database locking analysis can be done to find what process is keeping that table locked.
