10Gbe Cat6A SFP/Cable option for Catalyst 4500-X-32
mrguitar
Level 4
Level 4
I think i'm hosed, but checking the hive mind...
I have a dell server that has onboard 10Gbe copper RJ45s built-right into it...indicating Cat6a/7 is required.  Problem is I have a Catalyst WS-C4500-X-32 switch which is a little older and according to what I've found, there is not a compatible SFP for it:
https://tmgmatrix.cisco.com/?si=SFP-10G-T-X
Is that correct or will it work but just is not supported?  Are there any other options available?  3rd party? Need some advice ASAP please.  Thanks in advance.
Ed
5 Replies 5
Are you sure this switch does not support SFP-T ?
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-x-series-switches/data_sheet_c78-696791.html
Product Number
Description
System
Base System
Front to Back Airflow:
●  32x10 GE SFP+/SFP - WS-C4500X-32SFP+
●  16x10 GE SFP+/SFP - WS-C4500X-16SFP+
Back to Front Airflow:
●  32x10 GE SFP+/SFP - WS-C4500X-F-32SFP+
●  16x10 GE SFP+/SFP - WS-C4500X-F-16SFP+
Expansion Module (Optional)
8x10 GE SFP+/SFP - C4KX-NM-8SFP+
it supports SFP-T, but only 1G
Leo Laohoo
Get 3rd party.  Not only is it cheaper but 3rd party can "re-flash" the EE Prom so the switch will think it is something else.
Do you know which model works?  Recommendations please?  Thanks!
Contact FS.
