04-18-2015 03:43 AM - edited 03-13-2019 08:55 PM
No AXL Remote or LDAP Servers were found. A Unified Communications Manager and/or LDAP Directory server integration is required to import users.
how to solve it ?
04-18-2015 03:51 AM
Either you can import users from AD - for that you would need AD integration.
Ref: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/7x/administration/guide/7xcucsagx/7xcucsag306.html
Or You can import users from CUCM - for that you will need AXL integration with CUCM.
Ref: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/7x/administration/guide/7xcucsagx/7xcucsag240.html#pgfId-1067749
-Terry
Please rate all helpful posts and mark thread as answered if you have no other queries.
04-18-2015 04:15 AM
thanks.. but under phone system I have selected CUCM under telephone integrations.. But When I click edit I am not getting the options to add axl server.. any licencing issue ?
04-18-2015 04:27 AM
No its got nothing to do with licensing, AXL integration doesnt need license.
Whats the version of connection? Is your voicemail integration configured and working properly?
For AXL integration you need to go to Phone System>Edit>Cisco Unified Communications Manager AXL server
There add cucm servers and test the connectivity and you should be good.
-Terry
04-18-2015 05:15 AM
04-18-2015 06:27 AM
04-18-2015 06:34 AM
Thanks for the support from all of you....
I have solved this problem... It was internet explorer compatibility settings problem...
Thanks again
04-18-2015 06:54 AM
thanks for updates.
could u explain what exactly was issue and how did u resolve it?
which IE version u are using ?
regds,
aman
