Delay in Starting RTP
venkat.kt
Hi All,
We have an inter cluster trunk between CCM versions 3.3(3) and 4.1(2). Both the Callmanagers are located in same LAN.
If I make a call between clusters, the call setup is immediate. But after the handset is picked, no voice flow for 2 seconds. After 2 seconds, voice flow starts. No delay or jitter noticed later.
Any of you have noticed this kind of problem?
Venkatesha Reddy
dgahm
Level 8
Level 8
I have seen this occur when Media Termination Point required was selected on the trunk configuration. It only seemed to happen with IOS MTP, 6608 MTP was OK.
