SRST long timeout for registation
I've set up an SRST environment with a 1751 as SRST router. My problem is about the time I had to wait before the IP Phones registering on the router. I've to wait 60 seconds at worst before the phones are operational again. On the call-manger-fallback configuration I've found the "keepalive <sec> " command but it affects only the time I had to wait before the registartion of the phones, when the CCM comes up after a failure.
Do you know if there is a way to change the the timeout before the SRST became fully functioning ?
Thanks in advance.
Francesco
ciscomoderator
Community Manager
Community Manager
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
