12-29-2017 02:21 AM - edited 03-01-2019 08:41 AM
we have purchased for our datacenter two new Cisco ASR1001-X.
On both of them the TenGigabitEthernet interfaces have no coniguration [1] , no SFPs and no cables connected.
In both of them we see errors (input, CRC) [2] on TenGigabitEthernet interfaces.
The errors increase even though the TenGigabitEthernet interfaces are shutdown and there are no cables connected on them [1].
Any idea ?
[1]
interface TenGigabitEthernet0/0/0
no ip address
shutdown
[2]
CR1#sh interfaces tenGigabitEthernet 0/0/0 | inc CRC
5374 input errors, 5166 CRC, 314297108 frame, 0 overrun, 0 ignored
CR1#
5375 input errors, 5167 CRC, 314302911 frame, 0 overrun, 0 ignored
[3]
Next reload license Level: adventerprise
cisco ASR1001-X (1NG) processor (revision 1NG) with 3729256K/6147K bytes of memo
ry.
Processor board ID FXS2124Q0D8
6 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
12-29-2017 11:56 AM - edited 12-30-2017 02:03 PM
This is normal, I've seen this as well. No shut then shut the interfaces down again. Also have you applied the licenses for the 10G interfaces (seen that give out errors as well). Otherwise the 10G int. won't work. I have seen interfaces not shutdown with no cables attached send out errors but it's usually a cable management packet trying to see if the other end is up. I bet if you plug in a cable back to back in the routers the errors will go away.
01-01-2018 10:28 PM
Thanks for your effort. I reply bellow.
I did it again, the errors continue to increase on 10G interfaces.
When I did no shut on 10G interfaces it prompted me to accept the license. I replied yes. The 10G interfaces are not used.
I do not have spare 10G SFPs.
01-02-2018 11:29 AM
01-03-2018 04:10 AM
Thanks. The issue is now submitted to TAC.
01-02-2018 11:32 AM
12-29-2017 11:56 AM
01-01-2018 10:29 PM
>> Do you see the same error's on the Gigabit int?
No
01-04-2018 04:59 PM
01-04-2018 10:42 PM
Yes. There is a bug in release 16.3.4 specific to ASR1001-X. It is fixed in 16.3.5 but I have not tried it yet.
https://quickview.cloudapps.cisco.com/quickview/bug/CSCvb78322
01-04-2018 10:43 PM
Thanks for the follow up.
