can prime be integrated with AD?
bwadlington
is it possible to integrate Prime with AD?
Hi ,
Yes its support authentication with AD
.http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-1/user/guide/admin/admin/security.html#wp1142726
Changing Login Module to MS Active Directory
Sandy
Marvin Rhoads
There are about 30 Cisco products with Prime in the name.
Some of them, such as Prime LMS and Prime Infrastructure, can use AD as an authentication store (but not for authorization). Others have no AD integration or relationship at all.
Which are you asking about?
