Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco Prime - Storage limitation with using Image repository
Serpent2010
I have device image files that want to be imported to Prime's repository, BUT I am concerned about the Prime server capacity limit.
Any advice, please
Note, I already setup an external NFS for config and backup files, but I am not sure if the NFS could be used for the device software images (.bin, .tar, or .ova)
Serpent2010
I maybe did not explain it well. I have a Cisco Prime Infra server and started to import Switches Images to its repository. Is this will cause a problem with the server disk capacity? if so, how to expand it
