Extract all files and folders from a nexus 7K
mnice
Hi guys,
I have a nexus 7K which causes me problems at startup (Loader mode), The bootflash was empty (It was formatted by someone) with difficulty I was able to copy the kikstart and NX-OS. Now at startup it asks me to configure the password I configure it but after finish to ask me others configuration like autoconfiguration, vdc ... etc, I tried with password created but not work (I use easy and complexe password) now I have a second 7K I want to copy all the bootflash and restore it on the first just to test the time to get a smartnet.
Can give me the command to copy all bootflash from nexus to tftp ? and after the command to extrac it to the sanother nexus.
Thx in advance.
Ruben Cocheno
@mnice
I would probably suggest using a USB if possible since any other methods might be longer due to the COPP profile in place.
You just need a USB stick 16Gbytes formatted and then copy usb....... bootflash: to transfer the image
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Hello Ruben,
Thank you for your return.
But I want to copy all bootflash (include all directory) to USB or TFTP, is it possible ?
Thx.
balaji.bandi
nexus what what sup module it is ?  use lower USB with fat format.
example video help you :
https://community.cisco.com/t5/data-center-and-cloud-videos/how-to-restore-a-cisco-nexus-switch-from-loader-prompt/ba-p/3101970
BB
