Duo and DNA
scshockley03
I am attempting to add an extra layer of protection to our DNA web access portal and want to know if I can implement duo for MFA. Is this possible? I have the duo authentication proxy setup and validated but cannot get DNA at interact with the proxy. Thanks in advance for any replies/responses.
  For upgrade I know it is possible to use proxy config. Never saw for GUI access but maybe you get some idea on this link
https://nefkens.net/updating-dna-center-experiences/
Thank you again for your response. I found the issue was actually in the configuration on the duo proxy server. Once that was corrected I was able to incorporate 2fa into our authentication process.
Good to know, thanks for sharing.
zoltan.borbas
Hi, Can you tell me pls what was the final solution? What did you change on Auth Proxy?
