Enable PVLAN edge on SG500 switch
djolenole
Hi all,
I want to enable PVLAN edge feature on our Layer 2 CISCO SG 500 switches.
Is command switchport protected-port enough to do that?
I would apply that command to range of ports.
Bogdan Nita
Hi djolenole,
The necessary configuration to enable Private Vlan Edge (protected ports) is switchport protected-port on interface config.
You probably will have to configure 2 interfaces , because the way it works is by blocking L2 traffic between 2 protected ports. Traffic between protected-port and non protected-port is allowed.
Bogdan
Bogdan Nita
Hi djolenole,
Bogdan
Thank you Bogdan!
