NOT ABLE TO ADD CAS TO CAM?
edwjames
Level 3
Level 3
What are the possible cause for this? Please guide.
Thank you.
**Share your knowledge. It’s a way to achieve immortality. --Dalai Lama** Please Rate if helpful. Regards Ed
Tiago Antunes
It can be a lot of different reasons like:
- No CAS license.
- No Connectivity to the CAS.
- Mismatch shared secret.
- Certificate problem.
- etc..
Are you getting any error message? Can you share it?
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
Tiago Antunes
- No CAS license.
- etc..
HTH,
Tiago
Not Installing License for CAS was the Problem.
Thank You
