SNMP/APS SONET and Interface
acovarrubias
Hi..
We  have  a  12006  running the version 12.0(32)SY13..  They  are running  Automatic Protection Switching (APS) and  Now we are trying to add a fault managment sofware , but  we  found  a problem with the  information that the 12 k router have in order to identify the  interfaces that belong to sonet via snmp
I´m walking trough  the "CISCO-APS-MIB" and I found the object  cApsStatusTable, where it  supose that  show me  the  relation between the  APS groups Sonets  ant  the  en d  interfaces, but  doesnt show anything..
Do anyone has work with snmp in the  APS over 12k routers, and  have  any  idea  of  how  map  via  snmp of the  SONET cards and the  end interfaces?
Here is the configuration
controller SONET 1/2/0
au-4 1 tug-3 1
tug-2 3 e1 1 channel-group 1 timeslots 1-31
  tug-2 3 e1 1 framing no-crc4
interface Serial1/2/0.1/1/3/1:1 --->end  interfaces
ip address x.x.x.x 255.255.255.252
no ip redirects
no ip directed-broadcast
load-interval 30
no cdp enable
I  also tried with the next  object below  and  it doesnt show me nothing
apsMapTable
            contains entries for each SONET LTE
            interface available on the system. The table serves two
            purposes. It can be used to locate SONET LTE
            interfaces that are not currently included in
            APS groups. It also provides a mapping from InterfaceIndex
Regr¿ards!!
acovarrubias
I found this  way, in order to  identify  if the  group that belong to APS group
I walked in the  “CISCO-APS-MIB” and I found this :
Walk to
.1.3.6.1.4.1.9.10.71.1.4.1
.1.3.6.1.4.1.9.10.71.1.4.1.4.1.50.0 = 884
.1.3.6.1.4.1.9.10.71.1.4.1.4.1.50.1 = 879
SONET 4/1/0---->ifindex  884
SONET 3/1/0-----> ifindex 879
With this object, I found that  the interfaces  ifdex indicated 884 and 879, belongs to the same APS´s group “50”
And  another point that I noticed, is  that  the last octet, from the object indicate if the interface index is protect or working,as you see below:
.1.3.6.1.4.1.9.10.71.1.4.1.4.1.50.0 = 884----à “0” indicate that the interface index  is protect
.1.3.6.1.4.1.9.10.71.1.4.1.4.1.50.1 = 879-à “1” indicate that the interface index is working.
And now  with “cAppStatusSwitchedChannel”, I found that the in the group “50”  the  active  interface is protect, because the value 1 indicate that the interface protect  is working , and if the value is “cero indicate that the working interface is the active, as you see below:
.1.3.6.1.4.1.9.10.71.1.2.1.8.50 = 1---> distinto a cero, indica que esta trabajando el modo protegido
Here is  an ouput from the  aps group
PE-MTY-4#sh aps group 2  --------->884
SONET 4/1/0 APS Group 2: protect channel 0 (Active) (HA)
        Working channel 1 at 192.168.54.58 (Disabled)  (HA)
        bidirectional, non-revertive
        PGP timers (extended for HA): hello time=1; hold time=10
                hello fail revert time=120
        SDH framing; SDH MSP signalling by default
        Received K1K2: 0x21 0x10
                Reverse Request (working); Bridging working
        Transmitted K1K2: 0x11 0x10
                Do Not Revert (working); Bridging working
        Remote APS configuration: working
        SF-BER Threshold=3; SD-BER Threshold=6
SONET 3/1/0 APS Group 2: working channel 1 (Inactive) (HA) ---->879
        Protect at 192.168.54.58 (bidirectional)
        PGP timers (from protect): hello time=1; hold time=10
        SDH framing
        Remote APS configuration: protect
