01-11-2007 12:32 PM - edited 03-03-2019 03:20 PM
I cant realise more than two simultaneous internet dialin.
I have a cisco 2821 and three dsl lines.
There are three ethernet interfaces and three dialer interfaces configured. Every dialer works fine but I cant connect more than two dialer at a time.
It seems the router have only two possible virtual-access ports.
Has anybody a configuration with more than two active internet dial-in with PPPOE.
01-11-2007 04:37 PM
Hi there,
The router can support as much virtual-access as its IDBs supports "show idb", which can't be 2, can you please post your configuration as well as "show idb".
best regards,
Mohammed.
01-12-2007 03:49 AM
Hi Mohammed,
thanks for your reply.
You are right. I try it again today and saw three virtual-access interfaces.
But I dont get a connect on all interfaces at a time.
The config is not ready but i think it is enough to get the connections.
Here is the config:
hostname Router
card type command needed for slot/vwic-slot 0/0
no aaa new-model
resource policy
clock timezone GMT 0
clock summer-time GMT recurring last Sun Mar 1:00 last Sun Oct 2:00
network-clock-participate wic 2
ip cef
no ip dhcp use vrf connected
ip dhcp pool VoIP
network 172.21.2.0 255.255.255.0
option 150 ip 10.0.1.80
default-router 172.21.2.1
ip dhcp pool User
network 172.21.1.0 255.255.255.0
default-router 172.21.1.1
dns-server 172.21.1.1
ip name-server 145.253.2.11
voice-card 0
no dspfarm
username cisco privilege 15 password 0 cisco
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
description *** Management ***
encapsulation dot1Q 1 native
ip address 172.21.0.1 255.255.255.0
interface GigabitEthernet0/0.10
description *** User-LAN ***
encapsulation dot1Q 10
ip address 172.21.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface GigabitEthernet0/0.20
description *** VoIP ***
encapsulation dot1Q 20
ip address 172.21.2.1 255.255.255.0
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/3/0
switchport access vlan 201
interface FastEthernet0/3/1
switchport access vlan 202
interface FastEthernet0/3/2
switchport access vlan 203
interface FastEthernet0/3/3
interface BRI0/2/0
no ip address
interface BRI0/2/1
no ip address
interface Vlan1
no ip address
interface Vlan201
description internet1-adsl
no ip address
ip nat outside
pppoe enable
pppoe-client dial-pool-number 1
interface Vlan202
no ip address
ip nat outside
pppoe enable
pppoe-client dial-pool-number 2
interface Vlan203
no ip address
ip nat outside
pppoe enable
pppoe-client dial-pool-number 3
interface Dialer1
description Internet-Dialin
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp pap sent-username xxx password xxx
interface Dialer2
ip nat outside
encapsulation ppp
shutdown
dialer pool 2
dialer-group 1
interface Dialer3
ip nat outside
encapsulation ppp
dialer pool 3
dialer-group 1
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2
ip route 0.0.0.0 0.0.0.0 Dialer3
ip http server
no ip http secure-server
ip dns server
ip nat source route-map 10 interface Dialer3 overload
access-list 1 permit 172.21.1.0 0.0.0.255
access-list 101 permit ip 172.21.1.0 0.0.0.255 any
access-list 102 permit ip 172.21.2.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map nonat permit 10
match ip address 101
route-map nonat permit 20
match ip address 102
control-plane
voice-port 0/2/0
voice-port 0/2/1
line con 0
login local
line aux 0
line vty 0 4
login local
transport input telnet
line vty 5 15
login local
scheduler allocate 20000 1000
ntp clock-period 17179935
ntp server 192.53.103.103
regards
Sebastian
03-16-2007 07:06 PM
Did you ever get this config running properly? Do you have an HWIC in this router?
Dan.
03-19-2007 04:51 AM
yes I have an HWIC Module.
It was not possible to realice more than two pppoe session on this module.
But I create a third dialin with one of the the fixed gig ports.
So the router runs with three dialins.
Sebastian
03-20-2007 03:06 PM
I think i have found why you cannot have more than two internet dialin's at one time.
conf t
int virtual-access ?
shows:
<1-2> virtual access interface number
If i'm right every dialer interface is attached to a virtual access interface. Thus only allowing you to have two dialer interfaces at one time.
Would this be a limit of the ios? I really need to be able to run four dialin's at one time.
Dan.
03-21-2007 01:29 AM
Hi Dan,
The problem with the virtual access interfaces is the same problem I find out.
I think you need HWIC-1FE interfaces instead of a HWIC-4ESW. It seems to be a problem with the interface or the internel module slot limitation.
Like I do you can realice two dialer an the HWIC-4ESW and two on the fixed installed ports at the same time so you have four dialin?s at one time.
I think this will work(my config runs with three dialers).
Sebastian
03-21-2007 08:07 PM
Thats a good idea. Would you mind posting your current config. I'm still having some trouble and I wouldn't mind comparing mine with yours.
Dan.
03-22-2007 12:33 AM
Hi Dan,
here is my config (part of it):
no ip address
duplex auto
speed auto
ip address 172.20.0.1 255.255.255.0
no snmp trap link-status
h323-gateway voip bind srcaddr 172.20.0.1
ip address 172.20.1.1 255.255.255.0
ip nat inside
ip address 172.20.2.1 255.255.255.0
ip nat inside
description 3-adsl
no ip address
duplex auto
speed auto
pppoe enable group global
shutdown
shutdown
interface Vlan1
no ip address
interface Vlan201
description 1-adsl
no ip address
interface Vlan202
description 2-adsl
no ip address
interface Dialer1
description 1-adsl
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname xxx
ppp chap password yyy
interface Dialer2
description 2-adsl
encapsulation ppp
dialer pool 2
dialer-group 1
no cdp enable
interface Dialer3
description 3-adsl
ip nat outside
encapsulation ppp
dialer pool 3
dialer-group 1
no cdp enable
ip dns server
ip nat inside source list 1 interface Dialer3 overload
access-list 101 permit ip 172.20.0.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 101 permit ip 172.20.1.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 101 permit ip 172.20.2.0 0.0.0.255 10.0.0.0 0.255.255.255
gw_uk01#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(4)XC5, RELEASE SOFTWARE (fc1)
Synched to technology version 12.4(5.13)T
In this sample I use 3 dialins but it must be simmilar to use 4 dialins. The gig int 0/0 is for internal and the dialer 3 is for internet access. the other two dialer are for vpn but not configured now.
Sebastian
03-22-2007 12:36 AM
The access-list 101 is not needed in this sample.
It is preparation for VPN (no nat).
