09-13-2018 10:15 AM
Hi When a lot vrf are created in ASR1k or Cal3K, it is inconvenient to find some routes. We do not know which vrf the route are in, so we have to type different vrf to test to find some routes. Do we have one command to show all routes in asr1k or cal3k? If it is bgp routes, we can use "all" keyword included in the show command to find it. But if it is for non bgp route, it looks like it not have this kind command. Thanks
09-13-2018 11:08 AM
09-13-2018 12:41 PM
it does not work for asr1k.
the link you mentioned above is for asr9k
09-13-2018 02:38 PM
not sure if 'show ip route vrf *' works. I couldn't find a command specifically for the ASR 1K...
