GLBP virtual IP-address doesn't work
Ilya Semenov
Hello, everybody!
I've configured GLBP between two routers (CR01 and CR02), but I can't use it's virtual IP from other router (CSW01) - so, there is no load-sharing nor redundancy. At the moment 95% of company's routing works without GLBP through CR01's physical interface and it works fine.schema.JPG
GLBP is configured as:
CR01#show glbp detail
Port-channel1.300 - Group 1
  State is Active
    3 state changes, last state change 5d18h
  Virtual IP address is 192.168.255.4
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 1.376 secs
  Redirect time 600 sec, forwarder timeout 14400 sec
  Preemption enabled, min delay 0 sec
  Active is local
  Standby is 192.168.255.2, priority 100 (expires in 8.576 sec)
  Priority 150 (configured)
  Weighting 100 (default 100), thresholds: lower 1, upper 100
  Load balancing: host-dependent
  Client cache enabled, 1 of 2000 entries used
  Group members:
    24e9.b3b8.f282 (192.168.255.2)
    24e9.b3bd.4f02 (192.168.255.1) local
  There are 2 forwarders (1 active)
  Forwarder 1
    State is Active
    MAC address is 0007.b400.0101 (default)
    Owner ID is 24e9.b3bd.4f02
    Redirection enabled
    Preemption enabled, min delay 30 sec
    Active is local, weighting 100
    Client selection count: 35, known clients: 1 of 1 (100%)
  Forwarder 2
    State is Listen
    MAC address is 0007.b400.0102 (learnt)
    Owner ID is 24e9.b3b8.f282
    Redirection enabled, 598.592 sec remaining (maximum 600 sec)
    Time to live: 14398.592 sec (maximum 14400 sec)
    Active is 192.168.255.2 (primary), weighting 100 (expires in 8.768 sec)
  Group clients:
    Forwarder 1 clients:
      885a.920b.783f   192.168.255.3         Age: 02:27:45.582  Updates: 33
    Forwarder 2 clients:
      None
CR02#show glbp detail
  State is Standby
    4 state changes, last state change 5d18h
    Next hello sent in 1.632 secs
  Active is 192.168.255.1, priority 150 (expires in 7.808 sec)
  Standby is local
  Priority 100 (default)
  Client cache enabled, 0 of 2000 entries used
    Note: Client details unavailable on this router - group is not Active
  Group members:
    24e9.b3b8.f282 (192.168.255.2) local
  Forwarder 1
    State is Listen
      2 state changes, last state change 5d18h
    MAC address is 0007.b400.0101 (learnt)
    Time to live: 14397.664 sec (maximum 14400 sec)
    Active is 192.168.255.1 (primary), weighting 100 (expires in 9.440 sec)
  Forwarder 2
    State is Active
      1 state change, last state change 6d02h
    MAC address is 0007.b400.0102 (default)
CR01#sh run | s glbp
 glbp 1 ip 192.168.255.4
 glbp 1 priority 150
 glbp 1 preempt
 glbp 1 client-cache maximum 2000
 glbp 1 load-balancing host-dependent
CR02#sh run | s glbp
 glbp 1 preempt
CR01#sh running-config interface po1.300
Building configuration...
Current configuration : 378 bytes
interface Port-channel1.300
 description CSW01 Routed Link
 encapsulation dot1Q 300
 ip address 192.168.255.1 255.255.255.248
 no ip redirects
 no ip unreachables
 ip flow ingress
 ip flow egress
 ip nat inside
 ip virtual-reassembly in
 glbp 1 priority 150
 glbp 1 preempt
CR02#sh run int po1.300
Current configuration : 324 bytes
 ip address 192.168.255.2 255.255.255.248
 no ip redirects
 no ip unreachables
 ip nat inside
 glbp 1 preempt
 On CSW01 I have:
CSW01#sh ip route vrf Border:
S*    0.0.0.0/0 [1/0] via 192.168.255.4 (It is 100% accessible from CSW01 with ping vrf Border 192.168.255.4 command)
      10.0.0.0/8 is variably subnetted, 50 subnets, 4 masks
(omitted - many prefixes)
but when I trace 8.8.8.8 I get:
CSW01#traceroute vrf Border 8.8.8.8
Tracing the route to 8.8.8.8
VRF info: (vrf in name/id, vrf out name/id)
  1 192.168.255.1 0 msec 4 msec 0 msec (This is IP of Po1.300 interface of CR01)
  2 x.x.x.x 0 msec 4 msec 0 msec
  3 x.x.x.x 0 msec 0 msec 0 msec
  4 x.x.x.x 4 msec 0 msec 0 msec
  5 x.x.x.x 4 msec 0 msec 0 msec
  6 x.x.x.x 4 msec 0 msec 0 msec
  7 x.x.x.x 0 msec 0 msec 4 msec
  8 x.x.x.x 20 msec 8 msec 20 msec
  9 x.x.x.x 12 msec
 10 8.8.8.8 12 msec 8 msec 8 msec
So, why CSW01 use 192.168.255.1 instead of 192.168.255.4, which is set as static next-hop for default routes?
There are some outputs below, which could be possibly useful:
CSW01#sh ip route vrf Border 192.168.255.4
Routing Table: Border
Routing entry for 192.168.255.0/29
  Known via "connected", distance 0, metric 0 (connected, via interface)
  Redistributing via ospf 102
  Routing Descriptor Blocks:
  * directly connected, via Vlan300
      Route metric is 0, traffic share count is 1
 CSW01#sh ip cef 192.168.255.4
192.168.255.0/29
  nexthop 192.168.255.34 Vlan450
CSW01#sh ip cef vrf Border 192.168.255.4
192.168.255.4/32
  attached to Vlan300
CSW01#sh ip cef 8.8.8.8
0.0.0.0/0
CSW01#sh ip cef vrf Border 8.8.8.8
0.0.0.0/0
  nexthop 192.168.255.4 Vlan300
I will provide all information you ask me.
Many thanks in advance,
Ilya
15 Replies 15
Hello
Your topology isnt physically correct, FHRP like glbp need to be able to send keepalive to each other, it looks like in you topology this isnt be allowed do to them not being physically connected to each other or connected by a L2 switch
The two glbp  and spoke rtrs need to be on the same subnet but your topology shows the glbp rtr on different interfaces and i guess different ip addressing
res
Paul
Kind Regards
Paul
in addition to Paul's remarks, post the full configuration of CSW01. We need to see how the GLBP segment/interfaces is/are connected.
Hello, Gentlemen,
many thanks for your replies.
I've updated the schema for better visualization.
All the routers CSW01, CR01 and CR02 could ping  these IPs 192.168.255.1, 192.168.255.2 and 192.168.255.3.
Here the full config of CSW01:
version 15.1
service compress-config
hostname CSW01
boot-start-marker
boot system flash bootflash:cat4500e-universalk9npe.SPA.03.04.00.SG.151-2.SG.bin
license boot level entservices
boot-end-marker
vrf definition Border
vnet tag 503
address-family ipv4
exit-address-family
vrf definition Contractor
vnet tag 504
address-family ipv4
exit-address-family
vrf definition DMZ
vnet tag 502
address-family ipv4
exit-address-family
vrf definition ForVPN
vnet tag 507
address-family ipv4
exit-address-family
vrf definition Management
vnet tag 500
address-family ipv4
exit-address-family
vrf definition Security
vnet tag 506
address-family ipv4
exit-address-family
vrf definition Servers
vnet tag 501
address-family ipv4
exit-address-family
vrf definition VoIP
vnet tag 505
address-family ipv4
exit-address-family
vrf definition Wireless
vnet tag 508
address-family ipv4
exit-address-family
vrf definition mgmtVrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa session-id common
clock timezone MSK 3 0
hw-module uplink select tengigabitethernet
udld enable
no ip source-route
ip vrf Liin-vrf
no ip domain-lookup
ip domain-name banya.com
ip dhcp excluded-address 192.168.221.1 192.168.221.100
ip dhcp pool Temp
vrf Servers
network 192.168.221.0 255.255.255.0
dns-server 8.8.8.8
default-router 192.168.221.1
ipv6 multicast rpf use-bgp
vtp domain stobonn.com
vtp mode transparent
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause mac-limit
errdisable recovery cause vmps
errdisable recovery cause storm-control
errdisable recovery cause inline-power
errdisable recovery cause arp-inspection
errdisable recovery interval 60
power redundancy-mode redundant
spanning-tree mode rapid-pvst
spanning-tree logging
spanning-tree vlan 1-4094 priority 0
redundancy
mode sso
vlan internal allocation policy ascending
vlan 2
vlan 3
vlan 5
vlan 8
vlan 12
vlan 13
vlan 14
vlan 15
vlan 22
vlan 25
vlan 26
vlan 27
vlan 28
vlan 56
vlan 66
vlan 71
vlan 98
vlan 99
vlan 100
vlan 101
vlan 102
vlan 103
vlan 105
vlan 106
vlan 107
vlan 108
vlan 115
vlan 156
vlan 180
vlan 199
vlan 260
vlan 261
vlan 263
vlan 300
name CSW01-CR Routed Link (vrf Border
vlan 400
vlan 405
vlan 450
name CSW01-FW01 (vrf Global)
vlan 451
vlan 452
vlan 453
vlan 454
vlan 455
vlan 456
vlan 457
vlan 458
vlan 459
vlan 600
vlan 601
vlan 700
vlan 701
vlan 702
vlan 800
vlan 801
vlan 802
vlan 803
vlan 804
vlan 805
vlan 806
vlan 807
vlan 911
vlan 1100
vlan 2000
vlan 2001
vlan 2002
vlan 2003
vlan 2005
vlan 2007
vlan 2100
vlan 3000
vlan 4044
vlan 4045
vlan 4052
vlan 4053
vlan 4056
vlan 4060
lldp run
interface Loopback199
vrf forwarding Management
ip address 192.168.200.1 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
interface Loopback201
ip address 10.255.1.1 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
interface Loopback202
ip address 10.255.1.2 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
interface Loopback203
vrf forwarding Servers
ip address 10.255.1.3 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
interface Loopback204
vrf forwarding DMZ
ip address 10.255.1.4 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
interface Loopback205
vrf forwarding Border
ip address 10.255.1.5 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
interface Loopback206
vrf forwarding Contractor
ip address 10.255.1.6 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
interface Loopback207
vrf forwarding VoIP
ip address 10.255.1.10 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
interface Loopback208
vrf forwarding ForVPN
ip address 10.255.1.14 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
interface Loopback209
vrf forwarding Security
ip address 10.255.1.20 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
interface Loopback210
vrf forwarding Wireless
ip address 10.1.255.30 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
switchport
switchport trunk allowed vlan 103,300,400,450-454,601
switchport mode trunk
switchport nonegotiate
interface Port-channel2
switchport
switchport trunk allowed vlan 103,300,400,450-455,601
interface Port-channel3
switchport
switchport trunk allowed vlan 3,99,100,103,107,199,263,800,2100,3000
interface Port-channel4
switchport
interface Port-channel5
switchport
switchport trunk allowed vlan 1,3,100,180,199,3000
spanning-tree bpdufilter disable
spanning-tree bpduguard disable
interface Port-channel6
switchport
interface Port-channel7
switchport
switchport trunk allowed vlan 99,100,103,2100
interface Port-channel8
switchport
switchport access vlan 3
switchport trunk allowed vlan 100,800
interface Port-channel9
switchport
switchport trunk allowed vlan 28,56,71,98,107,156,260,261,450-459,2001,2100
bandwidth 1500
interface Port-channel10
switchport
interface Port-channel11
switchport
switchport access vlan 600
switchport mode access
interface Port-channel12
switchport
interface Port-channel13
switchport
switchport trunk allowed vlan 3,199,702,801,1100,2002-2004,2100
interface Port-channel14
switchport
interface FastEthernet1
vrf forwarding mgmtVrf
no ip address
speed auto
duplex auto
interface GigabitEthernet1/1
switchport trunk allowed vlan 1-198,200-4094
interface GigabitEthernet1/2
switchport access vlan 2
switchport trunk allowed vlan 2,199
interface GigabitEthernet1/3
switchport trunk allowed vlan 66,103,156,199,801
interface GigabitEthernet1/4
switchport trunk allowed vlan 1,15,27,199,801
interface GigabitEthernet1/5
interface GigabitEthernet1/6
interface GigabitEthernet1/7
switchport trunk allowed vlan 199,801,2007
interface GigabitEthernet1/8
channel-group 13 mode active
interface GigabitEthernet1/9
switchport trunk allowed vlan 199,801,911
interface GigabitEthernet1/10
channel-group 6 mode active
interface GigabitEthernet1/11
switchport access vlan 103
interface GigabitEthernet1/12
switchport access vlan 100
interface GigabitEthernet2/1
switchport trunk allowed vlan 1-99,101-198,200-4094
interface GigabitEthernet2/2
switchport trunk allowed vlan 1,15,22,105-108,156,199,804,4044,4045,4056
interface GigabitEthernet2/3
switchport trunk allowed vlan 22,108,156,199
interface GigabitEthernet2/4
switchport trunk allowed vlan 2,14,22,199,4052,4053,4060
interface GigabitEthernet2/5
switchport trunk allowed vlan 2,199,2001
interface GigabitEthernet2/6
interface GigabitEthernet2/7
interface GigabitEthernet2/8
interface GigabitEthernet2/9
switchport access vlan 108
no lldp transmit
no cdp enable
spanning-tree bpdufilter enable
interface GigabitEthernet2/10
interface GigabitEthernet2/11
switchport access vlan 107
interface GigabitEthernet2/12
interface TenGigabitEthernet3/1
no switchport
vnet trunk
ip address 192.168.255.17 255.255.255.252
interface TenGigabitEthernet3/2
interface GigabitEthernet3/3
interface GigabitEthernet3/4
interface GigabitEthernet3/5
interface GigabitEthernet3/6
interface TenGigabitEthernet4/1
no switchport
vnet trunk
ip address 192.168.255.21 255.255.255.252
interface TenGigabitEthernet4/2
interface GigabitEthernet4/3
interface GigabitEthernet4/4
interface GigabitEthernet4/5
interface GigabitEthernet4/6
interface GigabitEthernet5/1
switchport access vlan 22
switchport trunk allowed vlan 22,199
interface GigabitEthernet5/2
switchport voice vlan 801
interface GigabitEthernet5/3
interface GigabitEthernet5/4
interface GigabitEthernet5/5
interface GigabitEthernet5/6
switchport trunk allowed vlan 2002,2003,2100
interface GigabitEthernet5/7
switchport trunk allowed vlan 3,199,801
interface GigabitEthernet5/8
shutdown
channel-group 14 mode desirable
interface GigabitEthernet5/9
interface GigabitEthernet5/10
interface GigabitEthernet5/11
interface GigabitEthernet5/12
channel-group 8 mode active
interface GigabitEthernet5/13
interface GigabitEthernet5/14
interface GigabitEthernet5/15
channel-group 3 mode active
interface GigabitEthernet5/16
interface GigabitEthernet5/17
switchport access vlan 701
interface GigabitEthernet5/18
switchport access vlan 702
interface GigabitEthernet5/19
interface GigabitEthernet5/20
interface GigabitEthernet5/21
channel-group 5 mode active
interface GigabitEthernet5/22
interface GigabitEthernet5/23
channel-group 4 mode active
interface GigabitEthernet5/24
interface GigabitEthernet5/25
interface GigabitEthernet5/26
interface GigabitEthernet5/27
interface GigabitEthernet5/28
interface GigabitEthernet5/29
switchport access vlan 700
interface GigabitEthernet5/30
interface GigabitEthernet5/31
interface GigabitEthernet5/32
interface GigabitEthernet5/33
description USER
interface GigabitEthernet5/34
interface GigabitEthernet5/35
interface GigabitEthernet5/36
channel-group 7 mode active
interface GigabitEthernet5/37
interface GigabitEthernet5/38
switchport trunk allowed vlan 1-199,801-807,1100
interface GigabitEthernet5/39
interface GigabitEthernet5/40
channel-group 1 mode on
interface GigabitEthernet5/41
channel-group 2 mode on
interface GigabitEthernet5/42
switchport access vlan 199
interface GigabitEthernet5/43
channel-group 11 mode active
interface GigabitEthernet5/44
channel-group 12 mode active
interface GigabitEthernet5/45
channel-group 10 mode active
interface GigabitEthernet5/46
interface GigabitEthernet5/47
channel-group 9 mode active
interface GigabitEthernet5/48
interface GigabitEthernet6/1
switchport access vlan 801
interface GigabitEthernet6/2
interface GigabitEthernet6/3
interface GigabitEthernet6/4
interface GigabitEthernet6/5
interface GigabitEthernet6/6
interface GigabitEthernet6/7
interface GigabitEthernet6/8
shutdown
interface GigabitEthernet6/9
interface GigabitEthernet6/10
interface GigabitEthernet6/11
interface GigabitEthernet6/12
interface GigabitEthernet6/13
interface GigabitEthernet6/14
interface GigabitEthernet6/15
interface GigabitEthernet6/16
interface GigabitEthernet6/17
interface GigabitEthernet6/18
switchport access vlan 14
interface GigabitEthernet6/19
interface GigabitEthernet6/20
switchport trunk allowed vlan 1,3,14,99,156,199,801,1100
interface GigabitEthernet6/21
interface GigabitEthernet6/22
interface GigabitEthernet6/23
interface GigabitEthernet6/24
interface GigabitEthernet6/25
interface GigabitEthernet6/26
interface GigabitEthernet6/27
interface GigabitEthernet6/28
interface GigabitEthernet6/29
interface GigabitEthernet6/30
description USER
interface GigabitEthernet6/31
description USER
interface GigabitEthernet6/32
description USER
interface GigabitEthernet6/33
description ACRIBIA-Kontinent
interface GigabitEthernet6/34
interface GigabitEthernet6/35
description USER
interface GigabitEthernet6/36
interface GigabitEthernet6/37
description USER
interface GigabitEthernet6/38
description USER
interface GigabitEthernet6/39
description dlink-voice-router
interface GigabitEthernet6/40
description CR01 Gi0/4
interface GigabitEthernet6/41
description CR02 Gi0/4
interface Vlan1
no ip redirects
no ip unreachables
interface Vlan2
ip address 192.168.2.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache
interface Vlan3
ip address 192.168.3.1 255.255.255.0
interface Vlan5
ip address 192.168.5.1 255.255.255.0
ip helper-address 192.168.100.3
interface Vlan8
ip address 192.168.8.1 255.255.255.0
interface Vlan12
ip address 192.168.12.1 255.255.255.0
interface Vlan15
ip address 192.168.15.1 255.255.255.0
interface Vlan22
ip address 192.168.22.1 255.255.255.0
interface Vlan25
ip address 192.168.25.1 255.255.255.0
interface Vlan26
ip address 192.168.26.1 255.255.255.0
interface Vlan27
ip address 192.168.27.1 255.255.255.0
ip helper-address 192.168.100.2
no ip redirects
no ip unreachables
interface Vlan66
ip address 192.168.66.1 255.255.255.0
interface Vlan99
ip address 192.168.99.1 255.255.255.0
interface Vlan100
ip address 192.168.100.248 255.255.255.0
no ip redirects
no ip unreachables
standby 100 ip 192.168.100.1
standby 100 timers msec 250 1
standby 100 priority 255
standby 100 preempt
interface Vlan102
vrf forwarding DMZ
ip address 192.168.102.1 255.255.255.0
no ip redirects
no ip unreachables
interface Vlan105
ip address 192.168.111.1 255.255.255.0
no ip redirects
no ip unreachables
interface Vlan110
no ip address
shutdown
interface Vlan180
ip address 192.168.180.1 255.255.255.0
no ip redirects
no ip unreachables
interface Vlan199
ip address 192.168.201.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan263
bandwidth 4000
ip address 192.168.255.197 255.255.255.252
interface Vlan300
ip address 192.168.255.3 255.255.255.248
no ip redirects
no ip unreachables
interface Vlan400
ip address 192.168.255.11 255.255.255.248
no ip redirects
no ip unreachables
interface Vlan450
ip address 192.168.255.33 255.255.255.248
no ip redirects
no ip unreachables
interface Vlan451
ip address 192.168.255.41 255.255.255.248
no ip redirects
no ip unreachables
interface Vlan452
ip address 192.168.255.49 255.255.255.248
no ip redirects
no ip unreachables
interface Vlan453
vrf forwarding DMZ
ip address 192.168.255.57 255.255.255.248
no ip redirects
no ip unreachables
interface Vlan454
ip address 192.168.255.65 255.255.255.248
no ip redirects
no ip unreachables
interface Vlan455
ip address 192.168.255.169 255.255.255.248
no ip redirects
no ip unreachables
interface Vlan456
vrf forwarding VoIP
ip address 172.29.255.33 255.255.255.248
no ip redirects
no ip unreachables
interface Vlan457
ip address 192.168.255.202 255.255.255.248
no ip redirects
no ip unreachables
interface Vlan458
ip address 192.168.255.210 255.255.255.248
no ip redirects
no ip unreachables
interface Vlan459
ip address 192.168.255.218 255.255.255.248
no ip redirects
no ip unreachables
interface Vlan700
ip address 10.128.1.1 255.255.255.240
no ip redirects
no ip unreachables
interface Vlan701
ip address 10.128.1.17 255.255.255.240
no ip redirects
no ip unreachables
interface Vlan702
ip address 10.128.1.33 255.255.255.248
no ip redirects
no ip unreachables
interface Vlan800
vrf forwarding VoIP
ip address 172.29.250.1 255.255.255.0
no ip redirects
no ip unreachables
interface Vlan801
vrf forwarding VoIP
ip address 172.29.0.1 255.255.240.0
no ip redirects
no ip unreachables
interface Vlan911
ip address 192.168.112.1 255.255.255.0
ip helper-address global 192.168.100.2
ip helper-address global 192.168.100.3
no ip redirects
no ip unreachables
interface Vlan1100
ip address 192.168.110.1 255.255.255.0
no ip redirects
no ip unreachables
interface Vlan2007
ip address 172.30.7.1 255.255.255.0
no ip redirects
no ip unreachables
interface Vlan4044
ip address 192.168.255.89 255.255.255.252
no ip redirects
no ip unreachables
interface Vlan4045
ip address 192.168.255.93 255.255.255.252
no ip redirects
no ip unreachables
interface Vlan4052
ip address 192.168.255.141 255.255.255.252
no ip redirects
no ip unreachables
interface Vlan4053
ip address 192.168.255.161 255.255.255.252
no ip redirects
no ip unreachables
interface Vlan4056
vrf forwarding VoIP
ip address 172.29.255.9 255.255.255.252
no ip redirects
no ip unreachables
interface Vlan4060
vrf forwarding VoIP
ip address 172.29.255.25 255.255.255.252
no ip redirects
no ip unreachables
router ospf 101 vrf Management
router-id 10.255.1.2
capability vrf-lite
redistribute connected subnets
network 192.168.255.0 0.0.0.255 area 101
router ospf 102 vrf Border
router-id 10.255.1.5
capability vrf-lite
network 192.168.255.0 0.0.0.255 area 102
router ospf 103 vrf DMZ
router-id 10.255.1.4
capability vrf-lite
network 192.168.255.0 0.0.0.255 area 103
router ospf 105 vrf Servers
router-id 10.255.1.3
capability vrf-lite
redistribute static subnets
network 192.168.255.0 0.0.0.255 area 105
router ospf 106 vrf Contractor
router-id 10.255.1.6
capability vrf-lite
network 192.168.255.0 0.0.0.255 area 106
router ospf 107 vrf VoIP
router-id 10.255.1.10
capability vrf-lite
network 172.29.255.0 0.0.0.255 area 107
network 192.168.255.0 0.0.0.255 area 107
router ospf 108 vrf ForVPN
router-id 10.255.1.14
capability vrf-lite
network 10.128.1.0 0.0.0.255 area 108
network 192.168.255.0 0.0.0.255 area 108
router ospf 109 vrf Security
router-id 10.255.1.20
capability vrf-lite
network 192.168.112.0 0.0.0.255 area 109
network 192.168.255.0 0.0.0.255 area 109
router ospf 110 vrf Wireless
router-id 10.255.1.30
capability vrf-lite
network 192.168.110.0 0.0.0.255 area 110
network 192.168.255.0 0.0.0.255 area 110
router ospf 100
network 192.168.255.0 0.0.0.255 area 0
ip http server
ip http authentication local
no ip http secure-server
ip route 192.168.0.0 255.255.255.0 192.168.156.254
ip route 192.168.72.0 255.255.255.0 192.168.111.254
ip route 192.168.75.0 255.255.255.0 192.168.111.254
ip route 192.168.76.0 255.255.255.0 192.168.111.254
ip route 192.168.79.0 255.255.255.0 192.168.111.254
ip route 192.168.106.0 255.255.255.0 192.168.111.254
ip route vrf Border 0.0.0.0 0.0.0.0 192.168.255.4
ip prefix-list REDIST_LOCAL seq 10 permit 192.168.0.0/16 le 32
logging trap notifications
logging source-interface Loopback199 vrf Management
logging host 192.168.100.251 vrf Management
route-map RM_REDIST_LOCAL permit 10
match ip address prefix-list REDIST_LOCAL
snmp-server community public RO
I need to lab this, but check the channel group numbering:
On CSW01, you have configured channel group 2 for the trunk to CR02. I think the numbers have to match, so try:
interface Port-channel2.300
Can you actually ping CSW01 from CR01 (using the 192.168.255.2 address as the source) ?
Hi, Georg,
At CSW01 side to CR01 connects Port-Channel1 interface, to CR02 - Port-Channel2.
Do you really insist to rename both interfaces on CSW01 to match with CR01&CR02? It is impossible to do during workhours and workdays, I need request a maintainance window.
Here the output you've requested:
CR01#Ping 192.168.255.3 source 192.168.255.2
% Invalid source address- IP address not on any of our up interfaces
I've also added this:
CR01#Ping 192.168.255.3 source 192.168.255.1
Sending 5, 100-byte ICMP Echos to 192.168.255.3, timeout is 2 seconds:
Packet sent with a source address of 192.168.255.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/6 ms
CR01#
Thank you very much!
don't change anything, I'll lab this first...
Hello
Its a quite convoluted configuration - However i don't seem to see the default being directed towards the global rib table and also any statement telling the same rtr where to go for the return path for network192.168.255.0/29 into the vrf.
Can you trying adding this please:
ip route vrf Border 0.0.0.0 0.0.0.0 192.168.255.4 global
ip route 192.168.255.0 255.255.255.248 vlan 300
rtr1-2
glbp 1 load-balancing round-robin
res
Paul
Kind Regards
Paul
What I meant was:
CR01#Ping 192.168.255.2 source 192.168.255.1
That is CR01 to CR02...
Either way, I recreated the setup without the VRF, which works. I know you cannot do a lot of testing, but if possible try and configure just the bare minimum to start out with and see if you get it to work.
post the full configs of CR01 and CR02 as well...
Evening, Georg,
May I ask you? Should I see Virtual GLBP address in trace output? When I trace something beyond the GLBP routers...? I ask because I've configured a small lab in GNS and don't see Virtual address in trace.
Full show-runs from CR01 and CR02 below. Many thanks to you.
CR01:
version 15.1
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname CR01
address-family ipv4
exit-address-family
no ipv6 cef
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip domain name ashipyards.com
license udi pid C3900-SPE200/K9
ip address 192.168.200.254 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
ip address 10.255.254.5 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
ip address 10.255.254.2 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
no ip address
hold-queue 150 in
interface Port-channel1.103
encapsulation dot1Q 103
ip address x.x.x.x 255.255.255.248
ip nat outside
no ip redirects
no ip unreachables
ip flow ingress
ip flow egress
ip nat inside
glbp 1 priority 150
glbp 1 preempt
interface Port-channel1.400
encapsulation dot1Q 400
ip address 192.168.255.9 255.255.255.248
no ip redirects
no ip unreachables
interface Port-channel1.601
encapsulation dot1Q 601
ip address 192.168.255.146 255.255.255.248
no ip redirects
no ip unreachables
standby delay minimum 20 reload 20
standby version 2
standby 254 ip 192.168.255.145
standby 254 priority 255
standby 254 preempt delay minimum 20 reload 20 sync 10
standby 254 name HSRP_NAT
interface Port-channel1.603
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
channel-group 1
interface GigabitEthernet0/3
no ip address
duplex auto
speed auto
channel-group 1
router-id 10.255.254.2
capability vrf-lite
router ospf 102
router-id 10.255.254.5
default-information originate metric 10
ip forward-protocol nd
no ip http server
ip flow-export source Loopback199
ip flow-export version 5
ip flow-export destination 192.168.100.250 9997 vrf Management
ip nat Stateful id 1
redundancy HSRP_NAT
mapping-id 10
mapping-id 20
protocol udp
ip nat translation timeout 600
ip nat translation tcp-timeout 400
ip nat translation udp-timeout 30
ip nat translation finrst-timeout 30
ip nat translation syn-timeout 30
ip nat translation dns-timeout 30
ip nat translation icmp-timeout 5
ip nat translation port-timeout tcp 80 20
ip nat translation max-entries all-host 400
ip nat translation max-entries host 192.168.100.2 15000
ip nat translation max-entries host 192.168.100.3 15000
ip nat translation max-entries host 192.168.100.56 15000
ip nat translation max-entries host 192.168.100.90 20000
ip nat translation max-entries host 192.168.55.5 8000
ip nat translation max-entries host 192.168.55.3 5000
ip nat translation max-entries host 192.168.100.83 20000
ip nat translation max-entries host 192.168.3.235 2000
ip nat pool NAT-POOL x.x.x.x x.x.x.x prefix-length 29
ip nat pool SERVERS x.x.x.x x.x.x.x prefix-length 29
ip nat inside source route-map NAT-POOL pool NAT-POOL mapping-id 10 overload
ip nat inside source route-map SERVERS pool SERVERS mapping-id 20 overload
ip nat inside source static tcp 192.168.100.90 25 x.x.x.x 25 redundancy HSRP_NAT mapping-id 20 extendable
ip nat inside source static tcp 192.168.100.90 443 x.x.x.x 443 redundancy HSRP_NAT mapping-id 20 extendable
ip nat inside source static tcp 192.168.100.90 465 x.x.x.x 465 redundancy HSRP_NAT mapping-id 20 extendable
ip nat inside source static udp 192.168.255.66 2020 x.x.x.x 2020 redundancy HSRP_NAT mapping-id 20 extendable
ip nat inside source static udp 192.168.255.66 2021 x.x.x.x 2021 redundancy HSRP_NAT mapping-id 20 extendable
ip nat inside source static tcp 192.168.71.12 5555 x.x.x.x 5555 redundancy HSRP_NAT mapping-id 10 extendable
ip nat inside source static 172.29.250.2 x.x.x.x
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip access-list standard ACL_NTP_CLIENT
permit 192.168.0.0 0.0.255.255
permit 10.0.0.0 0.255.255.255
ip access-list extended acl_local_nat
deny ip 192.168.100.0 0.0.0.255 any
permit ip 192.168.0.0 0.0.255.255 any
deny ip any any
ip access-list extended acl_local_servers
permit ip 192.168.100.0 0.0.0.255 any
permit ip host 172.30.100.5 any
permit ip host 172.30.100.4 any
deny ip any any
ip access-list extended acl_local_smtp
permit ip host 192.168.100.72 any
permit ip host 192.168.100.55 any
ip access-list extended acl_nat_mail
permit ip host 192.168.100.90 any
permit ip host 192.168.100.52 any
ip access-list extended acl_voip_servers
permit ip host 172.29.250.2 any
permit ip host 172.29.250.3 any
deny ip any any
access-list 99 permit 192.168.0.0 0.0.255.255
access-list 99 deny any log
route-map VOIP permit 30
match ip address acl_voip_servers
set ip next-hop x.x.x.x
route-map SERVERS permit 20
match ip address acl_local_servers
route-map NAT-POOL permit 10
match ip address acl_local_nat
control-plane
CR02:
version 15.1
hostname CR02
vrf definition Backup
address-family ipv4
exit-address-family
address-family ipv4
exit-address-family
clock timezone MSK 4 0
no ipv6 cef
no ip source-route
ip cef
ip address 192.168.200.253 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
ip address 10.255.253.5 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
ip address 10.255.253.2 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
interface Loopback254
vrf forwarding Backup
ip address 10.255.253.254 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
no ip address
hold-queue 150 in
ip nat outside
no ip redirects
no ip unreachables
ip nat inside
ip address 192.168.255.10 255.255.255.248
no ip redirects
no ip unreachables
interface Port-channel1.450
bandwidth 1000
encapsulation dot1Q 450
ip address 192.168.255.36 255.255.255.248
delay 100000
interface Port-channel1.451
bandwidth 1000
encapsulation dot1Q 451
ip address 192.168.255.44 255.255.255.248
delay 101000
interface Port-channel1.452
bandwidth 1000
encapsulation dot1Q 452
ip address 192.168.255.52 255.255.255.248
delay 102000
interface Port-channel1.453
bandwidth 1000
encapsulation dot1Q 453
ip address 192.168.255.60 255.255.255.248
delay 103000
interface Port-channel1.454
bandwidth 1000
encapsulation dot1Q 454
ip address 192.168.255.68 255.255.255.248
delay 104000
interface Port-channel1.455
bandwidth 1000
delay 105000
ip address 192.168.255.147 255.255.255.248
no ip redirects
no ip unreachables
ip nat inside
standby version 2
standby 254 priority 0
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex auto
speed auto
channel-group 1
no ip address
duplex auto
speed auto
channel-group 1
router eigrp 100
address-family ipv4 vrf Management autonomous-system 100
eigrp router-id 10.255.253.2
exit-address-family
address-family ipv4 vrf Backup autonomous-system 100
eigrp router-id 10.255.253.254
exit-address-family
redistribute connected metric 1000 1000000 255 255 255
redistribute static metric 1000 1000000 255 255 255
eigrp router-id 10.255.253.5
capability vrf-lite
router ospf 102 vrf Backup
capability vrf-lite
network 192.168.255.36 0.0.0.0 area 0
network 192.168.255.44 0.0.0.0 area 101
network 192.168.255.52 0.0.0.0 area 105
network 192.168.255.60 0.0.0.0 area 103
network 192.168.255.68 0.0.0.0 area 102
router ospf 100
redistribute connected metric 50 subnets
redistribute static metric 50 subnets
passive-interface Port-channel1.601
network 192.168.255.2 0.0.0.0 area 102
default-information originate metric 50
no ip http server
ip nat Stateful id 2
redundancy HSRP_NAT
mapping-id 20
mapping-id 10
protocol udp
ip nat translation syn-timeout 120
ip nat translation max-entries all-host 1000
ip nat inside source route-map LOCAL-NAT pool NAT-POOL mapping-id 10 overload
ip nat inside source route-map NAT-MAIL pool NAT-POOL mapping-id 10 overload
deny ip any any
deny ip any any
permit ip host 192.168.100.54 any
route-map RM_REDIST_LOCAL_BACKUP permit 10
set metric +1000000
route-map LOCAL-NAT permit 30
match ip route-source acl_local_servers
route-map NAT-MAIL permit 10
control-plane
Joseph W. Doherty
You are keeping in mind that GLBP load balances per source MACs? Traffic sourced from CSW01 would usually only present itself from one MAC. As such, it won't load balance across CR01 and CR02.
Hello, Joseph,
many thanks for your reply.
So, you mean that GPLB is not a proper solution in my case? Then, what else?
OSPF maximum-paths?
My primary goal is to provide load balancing and fault-tolerance for Internet connection. I have 2 ISPs...
Is CSW01 a L2 switch or a L3 switch? If the former, and hosts use the GLBP gateways, they should load balance. If a L3 switch, which routes to CR01 and CR02, there's a couple of way to load balance.
One method would be to run a dynamic routing protocol between the 3 devices, and have CR01 and CR02 as equal cost from CSW01.
Another method (similar to your GLBP approach), would be to use mHSRP on CR01 and CR02, and route to two virtual gateways, one active/hot on CR01 and the other active/hot on CR02.
Or, if you use p2p routed links between CSW01 and CR01 and CR02, you could also just have a static route to each.
Hi, Joseph, CSW01 is Cat4507 switch
"One method would be to run a dynamic routing protocol between the 3 devices, and have CR01 and CR02 as equal cost from CSW01."
I've added to maximum-paths to my OSPF configuration but it seems there is no result...(
I can't use EIGRP because of other, non-CISCO switches.
Could you please enlight me with this:
"Or, if you use p2p routed links between CSW01 and CR01 and CR02, you could also just have a static route to each." What do you mean?
Ilya
