05-29-2016 09:19 AM - edited 03-05-2019 04:06 AM
Hi everyone,
Original situation is that we had one IP Range 1xx.35.133.x/29 behind a Cisco C881-K9. The IP Range is being used on VLAN 1. The LAN goes to a Cisco ASA 5506 and there the traffic continues to our internal network.
Because I need more IP addresses we got a new IP Range 1xx.35.135.x/29. Those IP's are needed physically on virtual servers. Since I am no expert it is more difficult than expected to do it properly so I need your advise into it.
I was thinking of making a new VLAN with the IP Range on our Cisco Router and continue the traffic to a new interface on our Cisco ASA. The issue is that I want to have those address attached to my virtual machines without NAT?
How can achieve this in a secure and best way?
Thanks a lot for any suggestions and help
05-29-2016 10:23 AM
06-03-2016 06:16 AM
Ok, what I have done is as following
1. I've created the static route.
2. I've enabled a physical interface with the IP of the network with the name DMZ.
3. I've created a new DMZ-Vlan on the connecting switch
4. I've added the VLAN to the Hyper-V server Switch
5. I Added the IP to the new Virtual Machine with VLAN for DMZ
I don't have any response. Maybe I am wrong in this, because it is my learning curve:
1. I have attached a cable from my Router to the ASA. This is my DMZ interface
Do I need to configure something else, did I miss something here. I am not an expert in networking or in these type of configurations.
