VPN Split Tunnelling
levan5540
Dear members please see my lab config below, your input would be much appreciated, database-server is moving to amazon and which only accepts connections from HQ, I’ve got users vpn users dialling in HQ (split tunnelling) and I’d like this to stay this way.
How do i achieve to have traffic to server A (in public network) to go through vpn tunnel?
LAB#
LAB#
LAB#
LAB#sh run
Building configuration...
Current configuration : 2670 bytes
! Last configuration change at 12:11:03 UTC Mon Mar 10 2014
version 15.1
no service pad
hostname LAB
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
memory-size iomem 10
ip source-route
ip dhcp pool main
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.10
   dns-server 8.8.8.8
   lease 7
ip cef
no ipv6 cef
license udi pid CISCO887VA-K9 sn FCZ15269010
username admin privilege 15 secret 5 $1$ny10$Djfl2m6Pm.uORGCH5eFMy/
controller VDSL 0
crypto isakmp policy 1
 encr 3des
 authentication pre-share
 group 2
crypto isakmp client configuration group VPNUSERS
 key LNADMIN
 pool SDM_POOL_1
 acl 101
crypto isakmp profile ciscocp-ike-profile-1
   match identity group VPNUSERS
   client authentication list ciscocp_vpn_xauth_ml_1
   isakmp authorization list ciscocp_vpn_group_ml_1
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
 set transform-set ESP-3DES-SHA
 set isakmp-profile ciscocp-ike-profile-1
interface Loopback0
 ip address 172.16.16.16 255.255.255.0
interface Ethernet0
 no ip address
 shutdown
interface ATM0
 no ip address
 shutdown
 no atm ilmi-keepalive
interface FastEthernet0
 switchport access vlan 20
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
 switchport access vlan 10
interface Virtual-Template1 type tunnel
 ip unnumbered Loopback0
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile CiscoCP_Profile1
interface Vlan1
 no ip address
interface Vlan10
 ip address 10.10.10.10 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
interface Vlan20
 ip address xx.xx.217.195 255.255.255.248
 ip nat outside
ip local pool SDM_POOL_1 192.168.100.0 192.168.100.100
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 1 interface Vlan20 overload
ip route 0.0.0.0 0.0.0.0 xx.xx.217.193
logging esm config
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 101 remark CCP_ACL Category=4
access-list 101 permit ip 208.64.38.0 0.0.0.255 any
access-list 101 permit ip 190.93.249.0 0.0.0.255 any
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 transport input all
end
LAB#
There are a couple of config-changes to do:
First, the Server-traffic has to be included into your SPLIT-ACL:
access-list 101 permit ip host A.B.C.D any
Then, the VPN-traffic has to be sent back to the internet with NAT:
access-list 1 permit 192.168.100.0 0.0.0.127
  ip nat inside
  ip nat inside
levan5540
Thanks a lot Karsten :)
