SD WAN ISR 1100 Router as Normal DMVPN Router as Temporary Requirement
makarand17zx
Hello Team,
Can we configure this 1100 series SD WAN Router as normal DMVPN router?
C1121X-8PLTEP
We have this requirement as Temporarily.
We are observing that we can't run or create crypto policy on this router.
is this possible in reality?
You need provide more information :
show version (full)
show license (information where it show all the license you have)
show license feature
Sure you need security License to enable DMVPN.
BB
balaji.bandi
Change the Router from controller to Normal
# controller-mode disable
guide help you :
https://www.cisco.com/c/en/us/td/docs/routers/sdwan/configuration/sdwan-xe-gs-book/install-upgrade-17-2-later.html
BB
Hi Balaji,
We did disable controller mode. Rebooted as well.
We are not able to enter these command -
If this related to license or something else ....
thanks
show version (full)
BB
