02-26-2024 10:47 AM
I have a question.
If configuring an AAR policy, and you set the SLA Class to strict with a preferred colour, does that render the SLA class performance moot, as even if the SLA is breached, it will still only use the "strict" colour?
Thanks!
Solved! Go to Solution.
02-26-2024 01:52 PM - edited 02-26-2024 01:53 PM
If the Preferred route not available, then if other SLA matches it uses that path - again it all depends how this was configured on the policy - better look below example : (for understanding)
Good video explanation :
02-26-2024 09:21 PM
preferred color + strict = if there is no path that meets SLA using preferred color > then traffic is drop
02-26-2024 09:21 PM
03-15-2024 04:59 AM
Thanks - much appreciated!
