PSIRT Alerts not reporting all affected Devices
Nathan Young
I have switches that are the same model with the same software version.  However, the PSIRT alerts does not indicate that they are all affected.  I did verify and both should be included in the alert.
Chris Camplejohn
PSIRT automation also looks at the configuration to see if the vulnerable feature is enabled. If you share the specific model, version and PSIRT you see the discrepancy, I can at least double-check on that part.
