04-17-2024 05:50 AM
Hi All,
I came across a strange issue today. I have a C9300-48S-A Switch but the show version output of the switch shows that the switch has an Essentials license on it.
Below snap for quick ref:
Is this an error from Cisco or have I missed something?
Any guidance would be of great help.
Solved! Go to Solution.
04-17-2024 06:44 AM
According to the output you posted, the license is "network-essentials".
04-17-2024 06:14 AM
Suggest use the "sh license authorization" command. It should tell you the license that the switch was purchased with. Post the out put if you wish.
04-17-2024 06:44 AM
