07-21-2017 01:46 AM - edited 03-08-2019 11:24 AM
We have configure the etherchannel in our cisco 2960-X to SG350X successfully with 2 x 10G SFP+.
In 2960X we are able to see the BW (bandwidth of 20000000 kbit/sec using the command show int po1
However when issue show int po1 in SG350X it only display limited information. Only few lines.
We cannot find the BW line that show us the bandwidth is 20000000 kbit/sec.
If we go to browser it only show us the Speed 10G at the LAG Settings (under Port Management).
How can we display that the LAG created in SG350X for 2 x 10GB have the bandwidth of 20G ??
Thank you.
07-21-2017 05:30 AM
the SG350 has only a limited command set. I guess your only option is to use 'show interfaces counters' and add both up to get the channel throughput...(oage 399 of the attached user guide):
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/CLI_Nikola300_1_3_7.pdf
07-24-2017 08:39 PM
George,
Thank you for the information. We will check it up.
