04-29-2024 12:20 PM - edited 04-29-2024 02:49 PM
Hello everyone,
Over the weekend we lost power to the building. For the most part all our switch stacks came back online. One stack (2960x's) has one switch that remains frozen in the stack. When consoled into the master, it shows that switch 2 is removed. All the ports show down when looking at the ip int brief for that switch. If the switch is removed from the stack, it powers up fine and works correctly. When plugged back into the stack, it freezes at the step below. The CLI is frozen at the console, and it will not go past the election complete step. I have tried swapping the stack cables and having it plug into each switch in the stack without the loop (Switch 1 into 2, switch 1 into 3, Switch 3 into 1 and Switch 1 into 3, switch 2 into 3, switch 3 into 1) with no difference. The only time the switch responds and functions correctly is when it is removed from the stack. Previously before the power outage the stack functioned fine with all the members plugged in.
Any advice would be greatly apperciated.
: Detected stack cables at PORT1
Waiting for Stack Master Election...
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: EMAC Loopback Tests : Begin
POST: EMAC Loopback Tests : MAC Loopback Passed
POST: EMAC Loopback Tests : PHY Loopback Passed
POST: EMAC Loopback Tests : End, Status Passed
Election Complete
Switch 2 booting as Member, Switch 1 elected Master
Both the Master and switch 3 function fine in the stack.
04-29-2024 12:21 PM
04-29-2024 07:40 PM
Could be an issue with the stack ports. The stack ports could be damaged. I would suggest you open a TAC case and get the switch RMA
John
