11-18-2017 12:24 PM - edited 03-08-2019 12:47 PM
Hi All,
I'm playing wiht this below topology and EIGRP. Some details about the configuration:
R4: Loopback interface 155.1.4.4/32
R3:
R3#sh ip int br Interface IP-Address OK? Method Status Protocol Ethernet0/0 150.1.37.3 YES manual up up Ethernet0/1 150.1.13.3 YES manual up up Loopback0 155.1.3.3 YES manual up up ! ! D 155.1.1.1 [90/409600] via 150.1.13.1, 00:35:57, Ethernet0/1 D 155.1.4.4 [90/435200] via 150.1.13.1, 00:35:57, Ethernet0/1 D 155.1.6.6 [90/435200] via 150.1.37.7, 00:35:57, Ethernet0/0 D 155.1.7.7 [90/166400] via 150.1.37.7, 00:35:57, Ethernet0/0
R7:
R7#sh ip int br Interface IP-Address OK? Method Status Protocol Ethernet0/0 150.1.67.7 YES manual up up Ethernet0/1 150.1.37.7 YES manual up up Loopback0 155.1.7.7 YES manual up up ! ! D 155.1.1.1 [90/435200] via 150.1.37.3, 00:38:33, Ethernet0/1 D 155.1.3.3 [90/409600] via 150.1.37.3, 00:38:33, Ethernet0/1 D 155.1.4.4 [90/435200] via 150.1.67.6, 00:38:33, Ethernet0/0 D 155.1.6.6 [90/409600] via 150.1.67.6, 00:38:34, Ethernet0/0
R7#sh ip eigrp topology 155.1.4.4/32
EIGRP-IPv4 Topology Entry for AS(100)/ID(155.1.7.7) for 155.1.4.4/32
State is Passive, Query origin flag is 1, 1 Successor(s), FD is 435200
Descriptor Blocks:
150.1.67.6 (Ethernet0/0), from 150.1.67.6, Send flag is 0x0
Composite metric is (435200/409600), route is Internal
Vector metric:
Minimum bandwidth is 10000 Kbit
Total delay is 7000 microseconds
Reliability is 255/255
Load is 1/255
Minimum MTU is 1500
Hop count is 2
Originating router is 155.1.4.4
150.1.37.3 (Ethernet0/1), from 150.1.37.3, Send flag is 0x0
Composite metric is (460800/435200), route is Internal
Vector metric:
Total delay is 8000 microseconds
Load is 1/255
Minimum MTU is 1500
Hop count is 3
I would like to modify the configuratoin only on Router R3 so that R7 will choose the path to 155.1.4.4/32 via 150.1.37.3. The change should affect only the R4 lo0 interace.
I know how to achieve this via manipulate the config on other routers via the bandwith, delay, distance, offset-list. I just can't force R3 to be choosen as a better path for 155.1.4.4/32 from R7 instead R6.
Any advise welcome, thanks.
11-18-2017 02:19 PM - edited 11-18-2017 02:21 PM
You can use administrative distance to accomplish this task. Please let me share the config.
Try with this config on R3
conf t
access-list 4 permit host 155.1.4.4
router eigrp 100
distance 91 150.1.13.1 0.0.0.0 4
clear ip route 155.1.4.4
Hope it is useful
11-18-2017 02:29 PM
Hi Julio,
thanks for reply, but I want to achieve something else. With your proposal I have now:
R3: D 155.1.1.1 [90/486400] via 150.1.37.7, 00:00:11, Ethernet0/0 C 155.1.3.3 is directly connected, Loopback0 D 155.1.4.4 [90/460800] via 150.1.37.7, 00:00:11, Ethernet0/0 D 155.1.6.6 [90/435200] via 150.1.37.7, 00:00:11, Ethernet0/0 D 155.1.7.7 [90/166400] via 150.1.37.7, 00:00:14, Ethernet0/0
R7:
D 155.1.1.1 [90/460800] via 150.1.67.6, 00:02:41, Ethernet0/0
D 155.1.3.3 [90/409600] via 150.1.37.3, 00:02:40, Ethernet0/1
D 155.1.4.4 [90/435200] via 150.1.67.6, 01:44:00, Ethernet0/0
D 155.1.6.6 [90/409600] via 150.1.67.6, 01:44:01, Ethernet0/0
C 155.1.7.7 is directly connected, Loopback0
I want to achieve that the router R7 has a route for 155.1.4.4/32 via 150.1.37.3 by modifying only the R3 configuration.
11-18-2017 02:30 PM
I hate to say something is impossible, but in this case I think it is. I have changed the bandwidth and the delay to the highest and lowest values on BOTH interfaces on R3, and set the distance to 1 for incoming updates from R1, but that still isn't enough for R7 to prefer the route through R3. That really is all you can do to influence the metric...
11-18-2017 02:36 PM
Georg,
thanks for trying. I can't figure out either how to achieve this.
11-18-2017 02:45 PM - edited 11-18-2017 02:48 PM
If you want that R3 is preferred than R6 you must configure a lower AD than 90
R3
conf t
router eigrp 100
distance 89 150.1.13.1 0.0.0.0 4
So R7 will prefer R3 as next hop for the route 155.1.4.4 only, the rest will be known through R7, All the routes included on the ACL 4 will be marked with AD 89.
But if you want to have 2 routes (one to R6 and other to R3) into the routing table you need to have equal metric, so you need to modify the Delay on R3's interface facing to R1 otherwise you will have unequal load balance and just one route will be seen into the routing table.
11-18-2017 02:57 PM
Julio,
that doesn't help either:
R3: ! router eigrp 100 network 150.1.0.0 network 155.1.0.0 distance 50 150.1.13.1 0.0.0.0 4 ! access-list 4 permit 155.1.4.4 ! ! D 155.1.4.4 [50/435200] via 150.1.13.1, 00:00:04, Ethernet0/1 D 155.1.6.6 [90/435200] via 150.1.37.7, 00:00:04, Ethernet0/0 ! R7: D 155.1.1.1 [90/435200] via 150.1.37.3, 00:00:09, Ethernet0/1 D 155.1.3.3 [90/409600] via 150.1.37.3, 00:00:09, Ethernet0/1 D 155.1.4.4 [90/435200] via 150.1.67.6, 00:00:09, Ethernet0/0 D 155.1.6.6 [90/409600] via 150.1.67.6, 00:04:01, Ethernet0/0
The AD changed on R3, however this doens't worked for R7.
On Cisco website I found that the Administrative distance is not propagated to other routers ( URL )
11-18-2017 03:43 PM - edited 11-18-2017 03:47 PM
That is correct, there is a way and it is manipulating the hop count, metric maximum-hops <1-255> if you execute show ip route <prefix> you will see the hop count below. This method will work if the restriction is for R3. Otherwise manipulating delay, I dont suggest manipulate BW because it could be used for other service like QoS.
Please let me think in other way if there is.
11-19-2017 01:45 AM
I'm wondering if there is a problem with my virtual environment ? Even if I change the delay on both interfaces on R3, nothing happens:
R3#sh int e0/0 | in DLY MTU 1500 bytes, BW 10000 Kbit/sec, DLY 10 usec, R3#sh int e0/1 | in DLY MTU 1500 bytes, BW 10000 Kbit/sec, DLY 10 usec, ! R7: D 155.1.1.1 [90/409856] via 150.1.37.3, 00:04:10, Ethernet0/1 D 155.1.3.3 [90/409600] via 150.1.37.3, 00:05:42, Ethernet0/1 D 155.1.4.4 [90/435200] via 150.1.67.6, 00:00:03, Ethernet0/0 D 155.1.6.6 [90/409600] via 150.1.67.6, 00:05:46, Ethernet0/0 C 155.1.7.7 is directly connected, Loopback0
Descriptor Blocks:
Vector metric:
Load is 1/255
Minimum MTU is 1500
Hop count is 2
Composite metric is (435456/409856), route is Internal
Vector metric:
Total delay is 7010 microseconds
Load is 1/255
Minimum MTU is 1500
Hop count is 3
Or maybe this is not achievable to configure only R3 ??
11-19-2017 07:45 AM
Try to set up a delay of 2000 (delay 200) under the R6's interface facing to R4, if nothing happens you can clear the neighborship
clear ip eigrp neighbor
11-19-2017 08:38 AM
