Help me !!!
huyencc2008
I have a network diagram
Why I ping time out !
Could you please share your packet tracer file in order to find the root cause? it could be a routing problem.
Thank you in advance.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julios right if you could share the packet tracer files it would help.
2 things i was thinking about was is there any ACLs I'm the OCC router ? Use the command show IP access lists to check. Also can the server PT ping 172.26.61.9 and does it have a default route.
john
Dan Lukes
Off-topic here. Cisco Learning questions should be asked in appropriate community of Cisco Learning Network
