Increased SPAN (monitor) sessions in V15 IOS?
bwadlington
I was told by a TAC engineer in the past that the number of available monitor sessions would be increased from two to something greater than that upon upgrade of IOS to version 15.x.  I just upgraded my core 6509 VSS to 15.1(2)SY5 and there still seems to be a limit of two.  Was I told wrong, or is this possibly a licensing issue?  Thanks.
Mark Malone
I am running s2t54-advipservicesk9_npe-mz.SPA.150-1.SY5.bin and have 80 available as below
CORE(config)#monitor session ?
  <1-80>  SPAN session number
  egress  Egress SPAN sessions replication
Does it only show you 2 when you try to configure that ?
As you can see below, I currently have two Spans and one RSpan sessions configured.  When I attempt to configure another one, I get "Local Session limit has been exceeded"
pa01-6509-vss-12a#sh monitor
Session 1
Type                   : Local Session
Source VLANs           :
    Both               : 200-201,205-206
Destination Ports      : Gi1/7/46
Egress SPAN Replication State:
Operational mode       : Centralized
Configured mode        : Centralized (default)
Session 5
Source Ports           :
    Both               : Gi1/3/11,Gi1/3/15,Gi2/3/15
Destination Ports      : Gi1/7/17
Session 20
Type                   : Remote Destination Session
Source RSPAN VLAN      : 113
Destination Ports      : Gi1/7/40
pa01-6509-vss-12a#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
pa01-6509-vss-12a(config)#monitor sess
pa01-6509-vss-12a(config)#monitor session 2 ?
  destination  SPAN destination interface or VLAN
  filter       SPAN filter VLAN
  source       SPAN source interface, VLAN
  type         Type of monitor session
pa01-6509-vss-12a(config)#monitor session 2 source ?
  interface  SPAN source interface
  remote     SPAN source Remote
  switch     Switch number of IDS module
  vlan       SPAN source VLAN
pa01-6509-vss-12a(config)#monitor session 2 source int g1/3/1 ?
  ,     Specify another range of interfaces
  -     Specify a range of interfaces
  both  Monitor received and transmitted traffic
  rx    Monitor received traffic only
  tx    Monitor transmitted traffic only
  <cr>
% Local Session limit has been exceeded
Theres a restriction even on 15 , that's just 80 sessions but local span only 2 as well , as you can see rspan and erspan make up the rest
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-0SY/configuration/guide/15_0_sy_swcg/span_rspan_erspan.html#wp1176409
Thanks-been looking for that graphic.  Appreciate your time.
