N5K: HSRP/VRRP hello's not received (or sent) on VPC-peer link
exw32-pica
Hello network specialists!
I am having troubles with my n5k setup.
I have two N5K's, in VPC config.
HSRP Hello packets are not being forwarded on the VPC-peer link. So both devices are in HSRP active state.
I see (debug) that packets are being sent out the L3 vlan interfaces of both devices.
They are however not received by the neighboring device.
VLANs are active and in FWD state on peer-link.
NOTE: I have no L3 card! (Is this a problem?)
TEST1# sh module
Mod Ports Module-Type                       Model                  Status
1   32    O2 32X10GE/Modular Universal Plat N5K-C5548UP-SUP        active *
3   0     O2 Non L3 Daughter Card           N55-DL2                ok
Any ideas why this wouldn't work? VRRP same problem.
Version SW = 5.2(1)N1(7)
No licenses.
Nexus A:
no feature telnet
feature vrrp
feature tacacs+
cfs ipv4 distribute
cfs eth distribute
feature udld
feature interface-vlan
feature hsrp
feature lacp
feature dhcp
feature vpc
feature lldp
feature vtp
vpc domain 1
  peer-keepalive destination 10.10.10.2 source 10.10.10.1
  peer-config-check-bypass
  peer-gateway
interface Vlan2001
  no shutdown
  description TEST
  no ip redirects
  ip address 10.10.20.2/22
  hsrp version 2
  hsrp 2001
    preempt
    priority 90
    ip 10.10.20.1
interface port-channel4096
  description to_neighbor_5548
  switchport mode trunk
  switchport trunk native vlan 2
  spanning-tree port type network
  speed 10000
  vpc peer-link
## show cmds ##
TEST1# show vpc brief
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                     : 1
Peer status                       : peer adjacency formed ok
vPC keep-alive status             : peer is alive
Configuration consistency status  : success
Per-vlan consistency status       : success
Type-2 consistency status         : success
vPC role                          : primary
Number of vPCs configured         : 2
Peer Gateway                      : Enabled
Peer gateway excluded VLANs     : -
Dual-active excluded VLANs        : -
Graceful Consistency Check        : Enabled
Auto-recovery status              : Disabled
vPC Peer-link status
id   Port   Status Active vlans
1    Po4096 up     1,75,2000-2012,2200-2202
vPC status
id     Port        Status Consistency Reason                     Active vlans
1      Po1         up     success     success                    75,2000-200
        3,2006-2007
        ,2010-2012,
        2200,2202
2      Po2         up     success     success                    75,2004-200
        5,2008-2009
        ,2201
TEST1# show hsrp summary
HSRP Summary:
Extended-hold (NSF) disabled
Global HSRP-BFD disabled
Total Groups: 15
     Version::    V1-IPV4: 0       V2-IPV4: 15     V2-IPV6: 0
       State::     Active: 15      Standby: 0       Listen: 0
       State::  V6-Active: 0    V6-Standby: 0    V6-Listen: 0
Total HSRP Enabled interfaces: 15
Total Packets:
             Tx - Pass: 5730    Fail: 0
             Rx - Good: 0
Packet for unknown groups: 0
Total MTS: Rx: 9
TEST1# show hsrp group 2001 brief
                     P indicates configured to preempt.
Interface   Grp Prio P State    Active addr      Standby addr     Group addr
Vlan2001    2001 90   P Active   local            unknown          10.10.20.1
   (conf)
Nexus B:
no feature telnet
feature vrrp
feature tacacs+
cfs ipv4 distribute
cfs eth distribute
feature udld
feature hsrp
feature lacp
feature dhcp
feature vpc
feature lldp
feature vtp
vpc domain 1
  peer-keepalive destination 10.10.10.1 source 10.10.10.2
  peer-gateway
interface Vlan2001
  no shutdown
  description TEST
  no ip redirects
  ip address 10.10.20.3/22
  hsrp version 2
  hsrp 2001
    preempt
    priority 80
    ip 10.10.20.1
  speed 10000
  vpc peer-link
## show cmds ##
TEST2# show vpc brief
Legend:
vPC domain id                     : 1
vPC role                          : secondary
vPC status
        3,2006-2007
        ,2010-2012,
        2200,2202
        5,2008-2009
        ,2201
TEST2# show hsrp summary
HSRP Summary:
Total Groups: 15
Total Packets:
             Tx - Pass: 19125   Fail: 0
             Rx - Good: 0
Total MTS: Rx: 174
TEST2# show hsrp group 2001 brief
Vlan2001    2001 80   P Active   local            unknown          10.10.20.1
   (conf)
Reza Sharifi
To do layer-3 with HSRP, you need the daughter card with proper license (N55-BAS1K9).
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/data_sheet_c78-618603.html
Reza Sharifi
Hi Reza,
Thank you very much for your support!
I'm gonna look for a daughter card and a license.
Your answer is confirmed with the link below:
http://blog.cunningtek.com/routed_port/2012/06/nexus-55485596-and-layer-3-hsrp-dont-forget-the-license.html
By the way, I think it's strange that HSRP can be configured, and even a debug output shows hello packets being sent, without a single warning of the Nexus about a license.
Thanks for your help!
