Nexus 31108 QSFP
wromero19
If I have a Nexus 31108 and I add 4 QSFP modules QSFP-100G-CWDM4-S, Can I to set up an etherchannel to form a protchannel 400Gbps?
Thanks in advanced!
keglass
Level 7
Level 7
Wuilmer,
We are working on finding an answer for you. Thank you for your patience.
Kelli Glass
Moderator for Cisco Customer Communities
Hilda Arteaga
Hi wromero19, I hope you’re doing well.
It is possible to add etherchannels, however it’s very important to consider many details and network components in order to achieve it properly. In this particular case, we highly recommend you to contact Cisco TAC so an expert on this matter can assist you to identify the possibilities and the best methods to do it.
