Nexus 5k connection to a 6513 with a SFP-H10GB-CU3M cable
kwanm63my
I've got these cables that is connecting between my 6k and 5k chassis. On the 6k it's connected to a 10gig module WS-X6716-10GE running
s72033-advipservicesk9_wan-mz.122-33.SXI5.bin.  When I use this cable, SFP-H10GB-CU3M, nothing shows up as connected. However, if I use a LC transceiver on both ends and a fiber connection, everything connects so I know it's not a hardware issue. Are there additional configuration needed on the interface on both ends required when you use these types of cables ? Thanks all.
6k
sh interface status
Port         Name                       Status       Vlan       Duplex  Speed        Type
Te13/1       5k-A-Ethernet2/16  notconnect   1            full         10G       unknown
5k
sh interface status
Eth2/16       CORE-A-TENGIG_13/1    notconnec             1         full        10G     10g
Darren Ramsey
Level 4
Level 4
Have 3M and 5M SFP+ connected between 6K and 5K running SXI4a. I assume you have a X2 to SFP+ converter in the 6716?  No special settings needed.
http://www.cisco.com/en/US/customer/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/hardware.html#wp3051725
sho inv
NAME: "Interface Adapter Module Te8/9", DESCR: "Interface Adapter Module Te8/9" PID: CVR-X2-SFP10G
NAME: "Transceiver Te8/9", DESCR: "Transceiver 10Gbase-CU3M Te8/9" PID: SFP-H10GB-CU3M
NAME: "Interface Adapter Module Te8/13", DESCR: "Interface Adapter Module Te8/13" PID: CVR-X2-SFP10G
NAME: "Transceiver Te8/13", DESCR: "Transceiver 10Gbase-CU5M Te8/13" PID: SFP-H10GB-CU5M
sh interface status
Te8/9 corp-nex1 connected trunk full 10G 10Gbase-CU3M
Te8/13 corp-nex2 connected trunk full 10G 10Gbase-CU5M
My issue is not between the 10gig X2 connector to the 5K using the SFP with a regular fiber cable. It's when I make the connection using a SFP-H10GB-CU3M  cable. These cables look a bit like coxial cabling and they come with LC connectors on both end. They are a bit cheaper as you do not need to have two LC transceivers on both side and then use a fiber connection to complete the connection.  They do have limit on the distance so they come in limited lengths but  they do support 10G
kwanm63my
turn out to the cable for the reason. Even thought it looks and feel like the correct cable.. btw, to anybody reading this, there is a command to try too ( didnt' work for me because of the cables ) .  service unsupported-transceiver
the new cable even snaps with a click..
