11-20-2015 12:36 PM - edited 03-08-2019 02:47 AM
Hi all
In the nexus 7700 with what command is the redistribute connected , was replaced?
thanks.
Solved! Go to Solution.
11-20-2015 01:40 PM
The command is :
redistribute direct route-map"
You need to specify in route-map which interfaces you are going to redistribute
Hope it helps,
Masoud
11-20-2015 01:40 PM
The command is :
Hope it helps,
Masoud
