Hi Community,
I've got an issue with a Nexus 5k/2k - I'm trying to disable VTP on a dedicated Port just to be sure a switch
from a different vendor won't talk VTP with our network.
Regarding docu the per-interface command "vtp" and "no vtp" is implemented since 5.x.
I'm running 6.0(2)N1(2a) and the command is not available in interface-mode.
"no vtp ?" returns "*** No matching command found in current mode, matching in (config) mode ***"
feature vtp, of course, is enabled - the Nexus is also still talking VTP to another switch on other ports.
"feature vtp" is currently the only command in the config which includes "vtp".
I've got 2 Nexus 5548 running in one VPC-Domain and some n2k fex's (2232)connected to these 5k's.
does anybody have an idea how to disable the VTP on a specific port?
many thanks in advance,
Chris
