12-19-2017 03:18 AM - edited 03-08-2019 01:09 PM
I have a strange issue that I'm not able to figure out by myself. I have 4 N3k, all the same models, all running the same software code 7.0(3)I4(7). First two I setup into vpc cluster in a blink of an eye without any issues. The other two, following the same steps, I'm not able to pair.
I have 2x10G ports connected back to back (as port-channel 2) inside vrf vpc as peer-keepalive and that works fine. Port-channel connected as Po1(RU).
interface port-channel2 no switchport speed 10000 vrf member vpc ip address 100.64.0.1/30
Then I have vpc domain coniguration as follow:
s-core-sdc-1# sh run vpc version 7.0(3)I4(7) feature vpc vpc domain 1 peer-switch system-priority 100 peer-keepalive destination 100.64.0.2 source 100.64.0.1 vrf vpc peer-gateway auto-recovery ip arp synchronize s-core-sdc-2# sh run vpc version 7.0(3)I4(7) feature vpc vpc domain 1 peer-switch system-priority 200 peer-keepalive destination 100.64.0.1 source 100.64.0.2 vrf vpc peer-gateway auto-recovery ip arp synchronize
Next thing I have 2x40G ports connected back to back as L2 trunk (Port-channel 1) for vpc peer-link and this connection works perfectly fine ... untill I put vpc-peerlink command on it. Then I have error massage:
2017 Dec 19 10:34:44 s-core-sdc-2 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 1,10,42-44,50-51,997,999 on Interface port-channel1 are being suspended. (Reason: vPC peer is not reachable over cfs) 2017 Dec 19 10:34:45 s-core-sdc-2 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 1,10,42-44,50-51,997,999 on Interface port-channel1 are being suspended. (Reason: vPC domain/system id mismatch)
After that vpc is down and I can't do much about it ....
s-core-sdc-1# sh vpc consistency-parameters global Legend: Type 1 : vPC will be suspended in case of mismatch Name Type Local Value Peer Value ------------- ---- ---------------------- ----------------------- Vlan to Vn-segment Map 1 No Relevant Maps No Relevant Maps STP Mode 1 Rapid-PVST Rapid-PVST STP Disabled 1 None None STP MST Region Name 1 "" "" STP MST Region Revision 1 0 0 STP MST Region Instance to 1 VLAN Mapping STP Loopguard 1 Disabled Disabled STP Bridge Assurance 1 Enabled Enabled STP Port Type, Edge 1 Normal, Disabled, Normal, Disabled, BPDUFilter, Edge BPDUGuard Disabled Disabled STP MST Simulate PVST 1 Enabled Enabled Nve Admin State, Src Admin 1 None None State, Secondary IP, Host Reach Mode Nve Vni Configuration 1 None None VTP domain 2 xxx.sdc xxx.sdc VTP version 2 2 2 VTP mode 2 Transparent Transparent VTP password 2 VTP pruning status 2 Disabled Disabled Allowed VLANs - 1,10,42-44,50-51,997,9 - 99 Local suspended VLANs - 1,10,42-44,50-51,997,9 - 99 s-core-sdc-1# sh vpc consistency-parameters vlans Name Type Reason Code Pass Vlans ------------- ---- ---------------------- ----------------------- Vlan to Vn-segment Map 1 success 0-4095 STP Mode 1 success 0-4095 STP Disabled 1 success 0-4095 STP MST Region Name 1 success 0-4095 STP MST Region Revision 1 success 0-4095 STP MST Region Instance to 1 success 0-4095 VLAN Mapping STP Loopguard 1 success 0-4095 STP Bridge Assurance 1 success 0-4095 STP Port Type, Edge 1 success 0-4095 BPDUFilter, Edge BPDUGuard STP MST Simulate PVST 1 success 0-4095 Nve Admin State, Src Admin 1 success 0-4095 State, Secondary IP, Host Reach Mode Nve Vni Configuration 1 success 0-4095 Pass Vlans - 0-4095
Any ideas ???
Solved! Go to Solution.
12-19-2017 03:26 AM
Going through your config, you appear to have confused system-priority with role-priority. The system-priority command is used to define the LACP priority advertised from vPC ports, and naturally has to be identical on both vPC peers to make them appear from outside as a single box.
You need to set the system-priority to an identical value on both switches (or remove it entirely from both). If you want to define which switch is going to be the vPC primary, use role-priority command on both switches; this command can be set to different value on each switch. Lower value wins.
Best regards,
Peter
12-19-2017 03:26 AM
Best regards,
Peter
12-19-2017 03:33 AM
12-19-2017 04:09 AM
Hey,
Very much welcome! :)
Best regards,
Peter
