02-01-2018 04:44 AM - edited 03-08-2019 01:39 PM
Hello All - Refer the attached diagram. No LACP or VPC configured in the switches
Question: On which Interface of SWITCH-1 the MAC address of the Windows Server (configured with NIC Teaming) will be learned. In my setup, the MAC f4c9.d3c4.3fd7 is learned alternative between SWITCH-1 Ports Gig 1/5 and Gig 1/6?
If this MAC is learned alternatively (Flapping) between these 2 interfaces of SWITCH-1 does it create issue in network performance to the Server?.
regards,
SAIRAM
Solved! Go to Solution.
02-02-2018 01:55 AM - edited 02-02-2018 02:04 AM
Hi is that constantly resetting , did you run the full command it should show you what interface its originating from
xxxxxxx#show spanning-tree detail | inc ieee|occurr|from|is exec
Number of topology changes 192 last change occurred 2d23h ago
from GigabitEthernet0/1
id also look at the link below that Paul suggested, lacp wont work unless switches are stacked or in vss or vpc mode acting as one unit , you could have 1 active standby interface though stp by setting cost either
02-01-2018 05:07 AM
02-01-2018 07:19 AM
Hey Mark - In STP perspective, in SWITCH-1 both Gig 1/5 & Gig 1/6 is in DES Role FWD state. I could see the MAC of NIC is changing often between Gig 1/5 & Gig 1/6. This setup is working for many months without major issue, expect a little Request Timeout in Ping test
02-01-2018 07:38 AM
02-01-2018 07:56 AM
Thanks Mark - I will check the STP timers. By the way, what is the best practice. Do i have to configure Active/Standby in NIC?. Does LACP is a solution as well?
02-01-2018 08:48 PM
Hi Mark - This is the output from SWITCH-1
SWITCH-1#show spanning-tree detail | inc ieee|occurr
Number of topology changes 14318 last change occurred 00:25:44 ago
Number of topology changes 7826 last change occurred 00:25:44 ago
Number of topology changes 8329 last change occurred 00:53:30 ago
SWITCH-1#
02-18-2018 09:57 PM
Thank you Mark.
02-01-2018 05:57 AM
Hello
Link state Tracking (LST) is ideal for this -review it here -
res
Paul
02-01-2018 07:38 AM
Hey Paul - Thanks for response. I want to know, On which interface of SWITCH-1, the MAC address is learned as both the Links are in STP FWD state. Both the Links are in STP FWD state because the Topology i have given doesnt detect the loop, unless STP is running on the Server NIC. In my case Server NIC doesnt run STP
regards,
sairam
02-01-2018 08:10 AM - edited 02-01-2018 08:11 AM
Hello
the switch runs stp not the server -So you should be okay providing stp is active for the vlan the teamed nic is attached to.
res
paul
