SFP-10G-SR-S for C3850-24XS
matze123
Hi Guys,
is it possible to use the SFP-10G-SR-S Module for the C3850-24XS-S with the IOS Version 16.6.1 (Everest) and any Network Module (4x10G, 8x10G) installed?
Thanks in advance for your help!
Mathias
Seb Rupik
Hi there,
The 16.6.1 release notes state that the network module is supported:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-6/release_notes/ol-16-6-3850.html#pgfId-1265268
As for the SFP+, the compatibility matrix states that the minimum supported release is 3.7.1E which was the first image available for the switch, so you can infer that 16.6.1 will be supported:
https://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html#_Toc496021460
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
Thanks for your help!!
