10-22-2015 12:07 AM - edited 03-08-2019 02:19 AM
After Resetting the switch unable to enter into Express Setup.
Even 10.0.0.1 is not pininging but the "syst" and "stat" LEDs are Lit in green continuously.
10-22-2015 01:23 AM
switch might have gone into rommon during reset, can you get a console cable on it see what the output is showing in putty ?
http://www.omnisecu.com/cisco-certified-network-associate-ccna/how-to-use-putty-to-configure-or-monitor-a-cisco-router-or-switch.php
10-22-2015 08:29 AM
Thank you so much for the reply.
Problem rectified by console cable connection. Express setup completed .
11-20-2015 02:03 PM
I have this problem as well. How did you rectify it? I can access the console but haven't found a menu item related to restarting Express setup.
