Call does not work between two SX80
    I have two SX80 TelePresence Devices installed on same Network. I want to make call ( IP to IP ) between two Sx80 and the Result was no call Establish between them.
Are there any configuration required to do it from my side to add to the SX80?
Note: this two SX80 WORKING stand alone ( No CUCM or MCU).
Warm Regard,
Idris
Jens Didriksen
Level 9
Level 9
Log in using SSH and ping one from the other to see if they can see each other, also ensure CallSetUp Mode is set to "Direct" and set default call protocol to H.323.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
thanks Jens Didriksen
 How can make the H323 THE default call protocol ?
