Cisco TMS 15.6.1 and Webex configuration
rashmi814
All,
I am having issue with webex setting configuration in TMS, I have entered hostname as configured on Webex Admin page under Site setting. I am getting error message Connection Failure and could not connect to site. Verify that the hostname and site name are correctly configured.
I can ping sitename and access URL from TMS server.
How do I resolve this issue?
ronlewis
Are you setting up CMR Hybrid, and if so has the Webex site been configured for CMR Hybrid? You have TP Session types in the webex site?
As CMR Hybrid is now EoSale is why I ask....if so, have you reviewed the details in this guide; https://www.cisco.com/c/en/us/td/docs/telepresence/infrastructure/tms/config_guide/cmr_hybrid_15_0/cmrh_b_cmr-hybrid-configuration-guide.html
And partner training with VOD's is here, https://communities.cisco.com/community/donot-migrate/webex/webex_enabled_telepresence.
Your issue sounds like a connectivity issue, TMS tries to connect to Webex using port 80 or 443, firewall preventing connection most likely.
Otherwise you should open TAC support case for help with this
Ron Lewis
Cisco
