CUCM endpont for Cisco Spark Room Kit
Nuno Torres
what type of device we must create on CUCM to register a Cisco Spark Room Kit.
Nuno
Zoltan Kelemen
Hi Nuno,
The device type must be Cisco Spark Room Kit, however you must make sure to have the correct device pack installed on a supported CUCM version.
Please see the compatibility matrix for details
7 Replies 7
Zoltan Kelemen
Hi Nuno,
Hi Zoltan,
thanks for youy answer.
Do you know if there is a device package for version 9?
Once again, thanks for the support.
I believe minimum is 9.1.2something
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvd22818
And the dev pack for 9.1.2 is (minimum): cmterm-devicepack9.1.2.17151-1.cop.sgn
what device pack do we need to install on CUCM 11.5 to support all the room kit systems? please share the file path, thanks.
i'm running 11.5.1, and there is no "Cisco Spark Room Kit", just "Cisco Spark Remote Device"
Have you installed the device pack to add that new device type?
java
if this helps, please rate
