No CDR or CMR records from any Telepresence registered to CUCM
droberts
There's a bug about the CDR but I wanted to point out to Cisco there are no quality metrics either.  The TC software used to have something via SNMP but seems all absent with the upgrade to CE.
Has anyone found any workaround to collect these call and quality records?
6 Replies 6
Wayne DeNardi
There is a bug with CDRs when upgrading from TC to CE
One way to fix it is to factory reset the CE device, then reconfigure it and you should start receiving CDRs again.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Are you saying you received CDRs when telepresence registered to CUCM and running CE 8.X?
Can you confirm if the CMR files are also there?
No, sorry, these endpoints are registered to VCS and managed by TMS.
  • Before upgrade running TC software - call detail records were received by TMS
  • After upgrade to CE software - no call details records
  • After Factory Reset of CE endpoint and reconfiguration - call detail records received again.
This was with all CE based endpoints (SX20, SX80, MX300g2, DX80).  And a real pain with so many endpoints to do.
It could be worth a try of a factory reset of the CE endpoint in your environment too.
Wayne
Wayne
Okay, I've already moved them off VCS so really hoping Cisco gets CDR support for them just like I get for the phones soon.
Did you try a factory reset of a CE endpoint to see if that helped?
Are you running a version of CUCM with appropriate device files to support CE8 endpoints?
Other than the need to factory reset the endpoint after upgrading to CE software, I'm not aware of any other issues with CDRs.
Wayne
Wayne
davidhouska
TMS CDR for CUCM registered endpoints enhancement request -
CSCut12732
Description
Symptom:
No endpoint CDR in TMS for SX/DX/MX/C/EX and CTS endpoints registered to Call Manager and being managed by TMS for p2p meetings without MCU.
Conditions:
No endpoint CDR in TMS for SX/ DX /MX/ C/ EX and CTS endpoints registered to Call Manager and being managed by TMS for p2p meetings without MCU.
Workaround:
None
Further Problem Description:
