08-30-2015 03:42 AM - edited 03-18-2019 04:55 AM
Hi All,
i have a VM server getting this error on "VM ware Tools" Running (3rd-party/independent). status is unknown, tools are installed ,but not managed by VM ware.
please find the attached error while i tried to upgrade.
Abid
Solved! Go to Solution.
08-30-2015 01:14 PM
I noticed you're trying to upgrade the VMWare Tools for a TelePresence VCS. For the TelePresence VM servers that doesn't use a Windows OS, they their own flavor of VMware tools installed within the app, not sure, or even know if they can be updated as I've never see any documentation or mention of it anywhere.
12-09-2021 04:30 AM
Its an old post.
Cisco uses its own flavor of Linux for its telepresence servers which have a strict compatibility with VMware Vmtools.
Now they have moved to Open VM tools (OVT) which is open source and has better compatibility with VMware version.
08-30-2015 11:44 AM
See http://docwiki.cisco.com/wiki/VMware_Tools
08-30-2015 01:14 PM
09-01-2015 01:53 AM
Hi Patrick,
yes exactly but i think is because of the servers running on Linux based not windows.
12-09-2021 04:30 AM
Its an old post.
