Sending Caller ID to CUCM
Rashed Wardi
Dear All;
I have H323 Voice Gateway with a number of FXO ports, this gateway is defined in CUCM 8.5,
every thing is working fine, I can use the fxo port to send offline calls and recieve incomming call on fxo port, but when i recieve the call on the IP phone it does not displayed the Caller ID, instead of that it displaed "..Unknown Number",
My question is : How to display the caller ID for the calls comming on the FXO port, and that calls are forwarded to cucm.
Thanks in Advance,
Rashed Wardi.
7 Replies 7
zsafawi
Check if it's enabled under FXO voice port
caller-id enable
Make sure that your Telco have it enabled on their end.
Zouheir
it is enabled but still not work, and i test the pstn line, i can recieve the caller id by using normal analog phone.
please advise if there any configuration needed
Configure caller-id enable under voice-port.
Then if still trouble search forum for common issues and workarounds.
Hi Rashed
i have same exact issue
did you solve it ?
yes the proplem is resolved with me, i will give you the configuration as soon as possible.
Hello I have the same issue. Could I please ask how you resolved this?
Nic
Hi Rashed
i  have the same issue... can you please share how did you solve the issue.
Thank You
